Help Mounting Hitachi Miter Saw To Stand - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-21-2011, 11:05 PM   #1
Help mounting Hitachi Miter saw to stand
Hi folks,
Was wondering if I could get some help with someone who's done this before.
I'm an idiot when it comes to tools and home improvement, but after purchasing our first house and some disapproving looks by my wife, I've got no choice.
To aid me in my efforts, she was kind enough to purchase a Hitachi C12RSH sliding compound miter saw to replace an old Ryobi I had. She also got the Dewalt miter saw stand.
Difficulty: I have no idea how to mount the saw to the stand. As best I can tell, the saw only has 2 front holes for bolts and nothing in the rear. Am I supposed to drill a hole through the saw to fit the mounting brackets?
Any help (photos would be awesome) would be very much appreciated.
Thanks.
LarsD is offline   Reply With Quote
Old 02-22-2011, 06:40 AM   #2
Most stands will accomodate a variety of manufacturers saws, yours apparently does not. Recheck all combinations of hole patterns, if nothing matches, get out the drill or get a different stand. That 12" slider is a big saw, maybe too big for that stand.
Old 02-22-2011, 08:05 AM   #3
Rewards Points: 78
My saw did not fit the brackets for my Dewalt stand either, so I used a piece of 1/2" plywood as an adapter plate. The stand brackets are bolted to the bottom of the plywood, and the saw is bolted to the top of it. Works fine that way.
Old 02-24-2011, 07:34 AM   #4
I was hoping someone had one and knew or could suggest how to mount it. I've seen several pictures where it appears to be done properly, I just can't figure it out.
Old 02-24-2011, 08:52 AM   #5
Ravenworks's Avatar
A wife that buys tools, dude you have a great wife!
Ravenworks is offline   Reply With Quote
The Following User Says Thank You to Ravenworks For This Useful Post:
TheDoorGuy (03-03-2011)
Old 03-02-2011, 12:37 AM   #6
it seems your Hitachi does not fit your miter saw stand.i recently purchased the ryobi miter saw stand and my 12" dewalt miter saw fits perfectly.the ryobi miter saw stand has simple instructions with pics on how to mount the saw,and if i can remember right it also suggest if your miter saw does not fit you can use a mounting plate(piece of plywood) for an adapter to make it fit the stand.the ryobi stand was $79.99 at home depot,its very sturdy and easy to set up.keep trying...
jeff
jeffski1 is offline   Reply With Quote
Old 03-02-2011, 11:51 PM   #7
I guess I asked the wrong question.
I can't see how the saw would fit any miter saw stand as it only has bolt holes in the front to support any mounting bracket, though I could swear I've seen pictures of other people with the same saw mounted without using a plywood underboard.
I'd like to know how that was done.
Old 03-03-2011, 06:35 AM   #8
A door a day is all I ask
TheDoorGuy's Avatar
I will chime in with the above posts and say that you should do a little more research on stands.
Maybe call Hitachi and see if they recommend a specific model.
More importantly, as Raven said....Hang onto that great wife!!!
RC/DG
Richard The Door Guy
www.thedoorguy.com
TheDoorGuy is offline   Reply With Quote
Old 01-06-2012, 02:52 PM   #9
Look at the rear of the saw legs. It appears that the holes in these legs do not go all the way through. There are rubber inserts in there that can be pulled out from the bottom. They are tight so will need a little elbow grease. After you pull them out you will see that the holes for all 4 legs are open
dkuntz is offline   Reply With Quote
Old 01-06-2012, 11:05 PM   #10
Rewards Points: 81
My limited google search has shown that this saw is difficult to mount to a stand and Hitachi support is limited. It definitely looks like there are no holes in the back. Weird...? There are some you tube vids/reviews that may be helpful.
Total Tool is offline   Reply With Quote
Old 01-07-2012, 05:49 PM   #11
Too Old
Will you need to have the holes in the back if you bolt the front good?
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 01-07-2012, 06:25 PM   #12
Rewards Points: 13,446
That stand is way to flimy for that sized saw.
You will bust a nut trying to set it up and tear it down.
I have one and use this type stand.
http://www.ridgid.com/Tools/Miter-Saw-Utility-Vehicle/
I just drilled two holes in the back for mounting.
Old 01-07-2012, 07:50 PM   #13
Thanks for the replies, but this thread is from March. I've already solved the problem.
Old 01-07-2012, 08:30 PM   #14
In a little over my head
Rewards Points: 706
Lars....we're waiting.....HOW'd you solve the problem?
Closure, dude. We need closure.
ratherbefishing is offline   Reply With Quote
Old 01-08-2012, 09:51 PM   #15
Rewards Points: 81
LOL, I didnt even notice the necro bump. But yeah, what did you do Lars?
Miter Saw Stand - looking for sturdy and portable schm1eri Tools 18 11-28-2010 02:25 PM
Kreg Track System for Miter Saw Stand Klawman Carpentry 2 12-07-2009 03:22 PM
Miter saw stand and location Klawman Carpentry 20 12-05-2009 08:08 PM
Hitachi Miter saw, or other brand? leroyme Carpentry 25 10-27-2007 10:41 AM
Miter saw stand jonesiera Tools 9 09-03-2006 06:24 PM
