Help Me ID This Wood! - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 01:49 AM   #1
Help me ID this wood!
I hope you don't mind a newbie question. I'm pretty naive about wood/carpentry and am looking for some help from experienced eyes. Can anyone tell me what type of wood this table is made from?
Thanks in advance!
steenbean18 is offline   Reply With Quote
Old 11-28-2011, 01:57 AM   #2
Too Short? Cut it Again!
Nope. Looks like it might be pieces of cypress. Tell me more about where you found it or how it came to you. Where are you by the way? Please post general location to your profile.
I am looking for a table base and it looks like this piece was once one. The glass on top got broken? It is rather cool. Want to sell it? Or would you like me to send you the shape glass top you should have made for it.
Looks like someone epoxied the top already?
Can you see or count any ring growth? This will help place the species of the tree it came from. I don't see any in the photos which might suggest the table shown is not from a trunk but from branches. Again old cypress pops to mind first.
Old 11-28-2011, 07:13 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
If it is about the hardest wood you've ever seen, it's probably manzanita. But in the picture it doesn't look red enough. Did it come from the Southwest?
titanoman is offline   Reply With Quote
Old 11-28-2011, 07:46 AM   #4
kwikfishron's Avatar
Rewards Points: 90
Looks like Myrtlewood too me.
kwikfishron is online now   Reply With Quote
Old 11-28-2011, 08:05 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
I have a very similar table:
Mine is California Buckeye but there are other varieties
A. arguta (Texas buckeye)
A. californica (California buckeye)
A. flava (sweet buckeye, yellow buckeye)
A. glabra (fetid buckeye, Ohio buckeye, stinking buckeye, Texas buckeye)
A. octandra (sweet buckeye, yellow buckeye)
A. pavia (red buckeye)
A. sylvatica (painted buckeye)
A. turbinata (Japanese buckeye)
Coastal South Carolina
Old 11-28-2011, 11:29 AM   #6
Rewards Points: 502
Thanks in advance!
something with a big burl maybe?
forresth is offline   Reply With Quote
Old 11-28-2011, 02:09 PM   #7
Nope! Wrong color and manzanita would not have a cross section that large. Thanks for reminding me of perhaps my fave California tree though.
Old 11-28-2011, 04:44 PM   #8
Rewards Points: 468
It is calafornia buckeye wood. I have use lot's of it in tables. I still have some. They get the wood from stumps. They did then up. As far as i know no calafornia buck eye tree's. Not wht ohio is a buck eye state but the wood isn't like that. Nice wood It is a dry wood .
del schisler is online now   Reply With Quote
Old 11-30-2011, 12:44 AM   #9
Thanks for the replies! Of all the woods listed so far, the california buckeye looks pretty close. I can see a few rings, but they're not consistent like redwood. When we purchased it, it was listed as "sequoia" but it doesn't look dark enough or large enough to me. It's kind of hard to tell because it's pretty heavily epoxied. Does being coated already affect the value of the piece? We purchased it at auction. Also, the top has some cracks in the epoxy. Any ideas on repairing them? Other than that, it's a beautiful table! Our intent is to sell it, but it's tempting to keep it. TIA!
Old 11-30-2011, 07:34 AM   #10
Rewards Points: 468
All you have to do is make a pour of good epoxy right over the old stuff. It will blind any scratches and fill in the crack's in the old epoxy. Now make this in one pour . If you havent poured epoxy before. Let me give you a hint when you pour it will have little bubbles in the epoxy right after the pour. Now to get rid of that. Their are a couple way's they have a bubble breaker which is in a spray bottle which is just for this. You will have ask for it . You may have to order this epoxy and bubble breaker on line. Or if you have a butane tortch you go over the pour with the flame about around 4" above the epoxy you will see the bubble's break. Do this just after the pour. Now in about 1/2 hour do this again that will be enough. Now don't get to close or you will boil the epoxy. If this happen's wait tell the next day and it probly will look bad if so take a sander with 50 grit and sand it out now you will have to make another complete pour so all is not lost. I have poured 100's of these epoxy item's over the yrs. Also the same with dust or if you do this in the shop or where ever try and make sure their aren't any nite flying critter's about. Also put cardboard under the iten don't let the epoxy get on the floor or it will be their for ever. After it has set up over nite you will have to sand off the drip's around the edge. To put epoxy on the edge of the wood use a thro away brush and just brush epoxy on like painting don't spare the stuff. Good luck if more info need check back as far as being already coated doesn't make any difference should make it better the buyer doesn't have to do it
Old 11-30-2011, 01:01 PM   #11
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
One of the members on the DIY's sister site
http://www.woodworkingtalk.com/searc...earchid=752679
has this site for IDing wood,
http://www.hobbithouseinc.com/personal/woodpics/
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 12-01-2011, 08:01 PM   #12
I have some closer-up pictures of the table:
For those of you with experience in these pieces, any idea what it's worth?
Putting wood flooring on steps timbo59 Flooring 4 11-18-2011 06:20 PM
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 08:46 AM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
