Help With Lowering Recessed Lights - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-06-2011, 06:57 PM   #1
Rewards Points: 150
Help with lowering recessed lights
I'm going to put a drop ceiling in the basement and the height restriction for this side of the soffit is the sewer line. It is 3" below the floor joists at the lowest point.
I am planning on putting recessed lighting in for this area of the basement. What would be a proper way to mount the recessed cans so that they will be 3" lower than the floor joists?
Hopefully this request makes sense.
stradt03 is offline   Reply With Quote
Old 11-06-2011, 07:26 PM   #2
Are you using acoustical style drop ceiling panels? You can either use fluorescent lighting designed for drop ceilings, or you can plan out and install individual cans as needed. If you go with the individual cans, I would run the wiring before installing the drop ceiling. once the ceiling is in I would then install the cans. The benefit of this is you have the ceiling for a reference point for the cans.
Good luck!
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Old 11-06-2011, 08:35 PM   #3
Rewards Points: 150
Good luck!
I'm doing 2x2 panels for the ceiling. I am also planning on using individual cans.
Recessed lights in kitchen - need advice rfranco1 Electrical 3 01-29-2011 08:29 PM
Recessed lights, wiring, breaker buzzing, etc diyguy999 Electrical 3 12-21-2009 02:10 PM
Fire Hazard worry on Low wattage recessed lights usng 50w halogen bulbs jomieblumreich Electrical 7 08-15-2009 05:20 PM
installed recessed lights but now switch does not work auggie77 Electrical 2 08-02-2009 11:11 AM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 06:02 PM
