Help Installing Bifold Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-04-2008, 08:09 PM   #1
MT Stringer's Avatar
Rewards Points: 248
Help installing bifold doors
My Photos
I bought a prehung bifold door (48x80) for a closet. Since I've been sick this past week, I'm too tired and weak to give it my all.
How would you install the doors? In order to nail the jamb into the wall, I have to be inside the closet (where it is dark!)
The doors came screwed to the frame, so it looks to me that I need to remove the doors and then mount the frame.
It became obvious quickly that I need a helper, which I don't have at the moment.
Any suggestions for installing these doors would be greatly appreciated.
Note: I have at least 1/2 inch of play all around the door jambs to make adjustments with fillers or shims.
Mike
MT Stringer is offline   Reply With Quote
Old 11-04-2008, 08:26 PM   #2
All trades carpenter
Will there be casing around the jamb? If so install the casing on the unit first. Then put it into place, level and plumb the unit. Make sure your reveal is correct all around. You might even open and close the doors a couple of times to make sure it functions correctly. You then nail the casing to the wall when everything looks good. Then open the doors and go inside, shim, nail, and install casing on the inside. Good luck!
CrpntrFrk is offline   Reply With Quote
Old 11-04-2008, 08:36 PM   #3
remodeling pro
Install the trim moulding on the outside of the frame. Then remove the doors from the unit, insert into the
RO , level the head and tack it off. Now, reinstall the doors, and use them as a guide to position the vertical jambs for an equal reveal. Tack off the verticals, then open the door and shim the gap between the jambs and RO at the top, bottom, and two points between, marking the locatin of the shims on the jambs. Then install the interior trim, and shoot some long nails through the jambs at the marked locations of the shims, so they reach the rough framing.
troubleseeker is offline   Reply With Quote
Old 11-04-2008, 09:23 PM   #4
Rewards Points: 248
Sounds good to me.
Thanks for the help.
Mike
Old 11-05-2008, 08:00 PM   #5
Rewards Points: 248
I got the doors installed today and started on the second set but ran out of time (and strength). Dang I hope I start feeling better before this weeks over.
Thanks again for the help.
Mike
Old 11-05-2008, 10:24 PM   #6
Mike
Words are not enough! We need some pics! Drink a hot tottie to make you feel better!
Installing Interior Doors - slab jkrodger Carpentry 22 10-19-2008 07:22 PM
Bifold Laundry Closet Doors? DIYtestdummy Remodeling 2 02-14-2008 02:38 PM
Installing Interior Doors jte1130 Carpentry 9 02-10-2008 10:22 AM
Installing laminate around doors??!! RonR Flooring 8 01-05-2008 07:38 AM
Installing laminate around doors??!! RonR Building & Construction 1 12-30-2007 02:08 PM
