Help Finishing This Stair (pics Included) - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-18-2012, 06:18 PM   #16
Registered User
Rewards Points: 4,924
You need to build them again anyway, to fix the required 6'-8" headroom over all stairs AND the landing; http://publicecodes.cyberregs.com/ic...?bu2=undefined As well as the 3'x3' landing, etc. Cut your enlarged stairwell first, go from there, we can help!
Gary
Old 09-18-2012, 06:34 PM   #17
Thanks for the support. I'm afraid I have barely 6' over the landing only and upper parts, unless I steal some room to the insulation (about 1' in total) or build an entire dormer over it (this is not going to happen).
As you suggest, I'm rebuilding the entire thing, It was just a temporary stair but now have to go.
And actually, I changed my mind today, I'm going to convert all the space under it into storage, so at the same time gives support to the upper part of it and have a closet with a door. But I don't see how I can build a stair totally code complaint.
Gary
Pirulo is offline   Reply With Quote
Old 09-18-2012, 06:38 PM   #18
Stairguy
Millertyme's Avatar
Rewards Points: 508
Where are you measuring the headroom from, the platform or the step just above? What is your current rise and run?
Millertyme is offline   Reply With Quote
Old 09-18-2012, 07:28 PM   #19
Registered User
Yes, your headroom looks low in the last picture of the upstairs, if that is a normal height door... Best if you give us all the measurements; total rise, distance from top riser to wall, distance from back wall to closest window, etc. to help figure it out. The floor joists will need to be cut, possible new post at the right-angle landing turning point, carried down to basement/crawl? Do you have a permit for these structural changes?
Gary
Old 09-18-2012, 07:30 PM   #20
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Millertyme, look at the picture upstairs, the ceiling at the head of the stairs is too low, see the door, it is 6/8 and the head room at the head of the stairs is probably around 6'.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 09-18-2012, 09:57 PM   #21
Msradell's Avatar
Rewards Points: 90
Everyone keeps referring to 6'8" is being a requirement and it is in the US. The poster is in Canada, are the requirements the same there?
Msradell is offline   Reply With Quote
Old 09-19-2012, 12:09 AM   #22
Registered User
After a quick search; http://www.airdrie.ca/building_inspections/links.cfm
Change from existing headroom; 9.8.3.4= 81" to 82-5/8", worse than in U.S. (you had to ask, LOL) http://www.chba.ca/uploads/Policy%20...03-04-01_9.pdf
Helpful: http://municipalaffairs.gov.ab.ca/do...i/06BCI016.pdf
jiju1943- "Great minds..."LOL,
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
BigJim (09-19-2012)
New SOD going brown? Pics Included. the punisher Landscaping & Lawn Care 18 07-04-2011 01:36 PM
Stair Nose Attachment - HELP! BSponz1 Flooring 3 01-10-2011 02:31 PM
BackYard needs Help ASAP!! Pics included fiji-fa5 Landscaping & Lawn Care 20 04-29-2009 09:00 PM
blower fan not coming on (pics included) TitanTn HVAC 6 02-16-2009 09:48 PM
Need suggestions for Painting my game room... PICS included. jaysen Interior Decorating 8 11-13-2008 11:45 AM
