Help With A Fence To Cinder Block Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-29-2013, 03:00 PM   #1
Question
Help with a Fence to Cinder Block Wall
Hello Everyone,
I would like to attach a wood fence (with horizontal slats) to a cinder block wall. The goal is to get a look like this as cheaply as possible...
http://www.apartmenttherapy.com/look-modern-fence-50175
The existing cinder block fence looks very similar to this...
http://www.apartmenttherapy.com/how-...nder-bl-119216
(sorry best pic I could find on gis)
What I would like to do is attach wood stud (2x4s) to the cinder blocks going vertically and spaced 8 feet apart with tapcons or another concrete fastener (already have my hammer drill ready).
After which I will screw the horizontal slats to the studs using deck screws.
I have several questions:
1) I have a lot of extra 2x4 studs left over from a recent interior reno. Is it OK for me to use these 2x4s for the braces to the cinder block wall? Parts of the wood will be over a concrete patio while other parts will be over soil. If over the soil, should I treat it with anything prior to attaching to the wall, if so, what? Or should I not use these wood studs at all and only use pressure treated wood?
2) I am planning to use the following for the horizontal slats...
http://www.lpcorp.com/smartside/trim_fascia/
Mainly because I've read a lot about wood warping and I think this maybe the best material. Is this assumption correct?
I live in Los Angeles where the weather is 70s year round and not a lot of rain. Should I be overly cautious or go with something else. What would you recommend that's cheap and will not warp?
3) I live in a pretty windy area. Since the slats will be attached to the cinder block wall, wood studs, their weight and the give and take with wind will be a consideration. Are tapcons enough, or do you recommend another type of fastener (sleeve, wedge, etc). Keep in mind I don't want to spend 20 days putting this up
Thanks so much for any guidance!
avandelay is offline   Reply With Quote
Old 08-29-2013, 04:40 PM   #2
I would use only pressure treated wood, raised up from the ground at least a few inches. All the work you're going to do...don't compromise it by saving a few bucks with the 2X4s you already have
I think Tapcons would be fine. As you're attaching to a block wall, i can't imagine wind would be much of a concern.
Your structure will be close enough to the wall that I don't believe wind will be a factor, if I'm understanding your building plan.
RoyalAcresRod is offline   Reply With Quote
Old 08-29-2013, 04:52 PM   #3
Do you think I'm OK using siding as the material for the slats? May I get away with using actual wood.
I remember seeing actual wood next to the smart siding (similar dimensions). The boards were about a 1/3 cheaper.
Old 08-29-2013, 08:01 PM   #4
I would be concerned about going 8' with with either "smartsiding" or actual wood, without any intermediate supports.
I think it'll be pretty unsteady.
Old 08-29-2013, 08:19 PM   #5
Is that because they would sag over time?
Old 08-29-2013, 08:31 PM   #6
That, and "wag" when one pushes in on them. I'd have a vertical support every 4'
Old 08-30-2013, 10:07 AM   #7
Makes sense. I'll get some stringers and space them out at 4'. Thank you so much for all your help. Gonna start on this tomorrow!
Old 08-30-2013, 10:17 AM   #8
Sounds like a good Labor Day weekend project!
Tags
cinder block wall , fence
Safe to seal exposed cinder block wall in basement? cne24 Concrete, Stone & Masonry 4 09-20-2012 08:43 PM
painting exterior cinder block wall raised ranch Painting 2 08-11-2011 09:13 PM
Insulate Top of Cinder block wall HooKooDooKu Building & Construction 0 01-20-2010 11:58 PM
Cinder block wall - filler chazz Building & Construction 3 01-19-2010 04:01 PM
Creating passageway through cinder block wall ...? mark_p Building & Construction 7 09-14-2009 09:22 AM
