#1 |
Help with Door Casing
Hello everyone, I'm adding chair rail and door casing in my dining room. The entrance is an open walk way (~8ft wide 7ft high).
Problem is that the house was trimmed up with base and shoe molding and I need some ideas on how to run the casing. It looks goofy just sitting on top of the base. Help! What's the proper way to handle this? ![]()
#2 |
Haverhill Trade 1965
Usually casing is installed before baseboard. In your case, to make it look right, one of the new oscillating saws would be a good investment. You can get a fairly good one for less than $100.00. Practice first and they can be tremendously accurate. A guide block tacked on for a guide helps cut a nice smooth straight line.
#3 | |
Help with Door CasingQuote:
#4 |
Do the same and extend the board on the inside of the opening all the way to the floor. It should look just like a door jamb without the stop.
| The Following 2 Users Say Thank You to chitownken For This Useful Post: | Duckweather (12-14-2012), mae-ling (12-13-2012) |
#5 |
We are assuming you were going to use a jamb there too.
#6 |
Why are you running baseboard on the inside of the jamb? Not the way it's done in most cases.
The jambs were suppost to be under cut and the flooring run under the jambs so there's no gaps. |
#7 |
It's a drywalled opening that will be changed to trimmed.
#8 |
mae-ling is right. see the attached pic for a better look.
#9 |
I would say take the base off,put the casing up than cut your base to the casing.Looks like the base is fairly short pieces anyway.Plus if you cut it in place it will be hard to cut the base shoe with out screwing the floor up.
| Display Modes | |
