Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-19-2012, 10:27 AM   #1
Help with a dining table build
I'm in the middle of building a dining table. The top is made 3/4" birch plywood supported by an underframe of 2x2 pine boards and the entire top is covered in white oak veneer. I'm planning on attaching 4 stainless steel hairpin legs at the corners. The mounting plates on the legs have 3 screw holes and the recommended screw is #10 wood screws. I'll use 2" length screws (through both the 2x2's and the ply. I'm just concerned about whether this leg/screw combo will support the table top long-term. Any advice??
jbanks is offline   Reply With Quote
Old 01-19-2012, 10:32 AM   #2
MarginallyQualified
You appear to building downward. Build UP instead:
Attach your legs (whatever style and fastener) to support an under-structure.
That under-structure, in turn, supports the top (whatever material and fastener method).
Depending on the overall size... four spindly legs at the corners will probably not do well.
Old 01-19-2012, 10:53 AM   #3
Yes, I forgot to mention it's a pretty large table top. Approx. 92" L x 38" W. I'd guess it weights around 100 lbs.
Old 01-19-2012, 11:24 AM   #4
Disabled wood vet
titanoman's Avatar
All you can do is attach the legs and see what happens. Why would you have a bunch of strangers hypothesize when you're going to attach the legs and find out for yourself anyways?
titanoman is offline   Reply With Quote
Old 01-19-2012, 03:35 PM   #5
Ouch. I think that needs some rethinking
mrgins is offline   Reply With Quote
Portable table saw stand baldeagle51 Tools 3 11-14-2010 09:04 PM
Build my own kitchen dining table ChrisDIY Carpentry 0 08-23-2010 07:24 PM
Help please with table support Stonefury Carpentry 2 01-07-2009 02:05 AM
Replacement Track for Table w/ Leaves? NRutman Carpentry 5 12-31-2008 07:33 PM
