Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-21-2011, 08:00 AM   #46
Help determining angles
Originally Posted by n0c7 View Post
I tried the smallest turnbuckle and cable combination I could find and it seems the gate is just to small to lift it back to levelness.
This makes no sense. How can, "the gate is just to small to lift it back to levelness."?
The gate can be too large to lift back to level, but it can't be too small.
You have to know how to install the device to make it work correctly. If you attached it to the wrong diagonal, tightening actually pulls it out of square.
Ron
B. Franklin 1759
Old 08-21-2011, 09:44 AM   #47
I mounted the kit, adjusted to the maximum and the turnbuckle tops out before the gate is level - about half an inch too short. Way too much cable left over and if I had more distance it would be fine. How does that not make sense?
n0c7 is offline   Reply With Quote
Old 08-21-2011, 10:55 AM   #48
If you get the correct size mechanism for the gate size you have, it will work.
Sometimes you can modify a mechanism so it fits correctly.
Sometimes, things are so complicated that they have no solution.
Ron
B. Franklin 1759
Old 08-21-2011, 11:35 AM   #49
Mod
kwikfishron's Avatar
I can see where this might be one of those.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
bob22 (08-22-2011)
Old 08-21-2011, 11:46 AM   #50
I've got no formal carpentry training and I came here to ask questions and learn not be insulted by people who have the expertise. This thread has gone too far. Obviously it's a simple stick gate with a handful of options to reinforce it. I need to build some larger full size fence gates so I'm trying to learn by making mistakes on my small temporary deck gate.
Old 08-21-2011, 12:45 PM   #51
Mod
If you would have simply posted a picture of the gate and asked how to reinforce/brace it this thread wouldn’t be 50+ post long.
-NEW MEMBERS-
Old 08-21-2011, 02:53 PM   #52
Framing Contractor
You did this to yourself.
Your first post.
I want to install a diagonal brace on my fence gate. I'm not very good at determining angles. The two corners that it will meet are 90 degrees inside. What type of tool or method can I use to to mark this on my brace?
You were asked 1000x for measurements so that we could help you and give you some answered. I will ask you again in English. How come you didn't give the measurements of the gate? Can you give me one good reason why you haven't?
What is so difficult about that question>? Do you own a tape? If so can you read the tape to give measurements??????
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-21-2011, 10:30 PM   #53
Experienced
Jackofall1's Avatar
Here is a work sheet for Excel I put together for establishing center line lengths and angle cuts, just enter your data in the orange boxes, simple and easy.
Mark
45 deg angles on the 1 side of a 1xX amakarevic Carpentry 3 01-29-2011 06:11 PM
measuring angles - flooring felicity7 Flooring 3 12-29-2010 07:33 AM
Need some quick help with coffin angles. DangerMouse Building & Construction 6 01-27-2010 04:40 PM
Gable roof angles Enok Building & Construction 2 11-23-2007 09:49 PM
Determining Tonage Rze HVAC 2 10-17-2007 05:21 PM
