Help Determining Angles - Carpentry - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-19-2011, 04:17 PM   #31
Framing Contractor
Originally Posted by n0c7 View Post
Right, that's the easiest way. I guess my question goes beyond a simple gate for other spots where it's not easy to scribe the brace or other work from behind.
Take a picture of the other gates and post them. Scribing the gate you posted is as simple as it gets.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-19-2011, 09:17 PM   #32
Old School
Willie T's Avatar
I don't know, Ron, I think some of the solutions offered here are debatable.
Or not............
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
kwikfishron (08-20-2011)
Old 08-20-2011, 05:05 AM   #33
kwikfishron's Avatar
Rewards Points: 1,022
Ok, wrong choice of words. I guess there’s plenty to debate for some.
I was taught why waste even a one second of time thinking about it when you can just scribe it and be done.
kwikfishron is offline   Reply With Quote
Old 08-20-2011, 06:41 AM   #34
Perhaps a DB would ruin the looks on this gate project?
may I suggest you take the gate off and install some 3/8" stainless steel full length pins inside the wooden 2x2 spindles?
Marbledust is offline   Reply With Quote
Old 08-20-2011, 07:09 AM   #35
A couple of little triangle gussets in the corner is all it would take for that tiny gate.
Old 08-20-2011, 08:33 AM   #36
Rewards Points: 506
What if the gate were sagging and/or out of square? Then that simple, non-time-wasting slap-it and scribe-it solution would look hack because no thought was put into it.
(Is that a strong debate point? I never took debate in school)
jlmran is offline   Reply With Quote
Old 08-20-2011, 08:52 AM   #37
Rewards Points: 5,336
You would square the gate before you designed the cross brace.
Ron
B. Franklin 1759
Old 08-20-2011, 09:09 AM   #38
Framing Contractor
This is what happens when the OP doesn't give enough information. If it's the gate he posted the picture of....a 2 year old can just scribe the brace. He can take it off and scribe it. The OP came back and said something about other gates that could be difficult to do. If those gates are built and hung already....he can just take them down...all this other debating is useless.....
Joe Carola
Old 08-20-2011, 10:12 AM   #39
And once again the time has come to:
Ron
B. Franklin 1759
Old 08-20-2011, 10:45 PM   #40
Rewards Points: 518
Originally Posted by Ron6519 View Post
What you would do is take into account each individual circumstance and come up with a solution on a case by base basis.
I'm a little confused, now that I see the picture of the gate. I don't know how a thin guide wire and a turn buckle will be more obtrusive then a thick diagonal piece of wood (or 2). From a design standpoint in a deck railing with only horizontals and verticals I would minimize the diagonal visuals.
But, it's your deck.
I tried the smallest turnbuckle and cable combination I could find and it seems the gate is just to small to lift it back to levelness.
n0c7 is offline   Reply With Quote
Old 08-20-2011, 10:47 PM   #41
Rewards Points: 518
No problem...all you need is the height...width and calculator. It's that simple. I asked you before what the measurements are. If you don't tell us... you'll never get your answer.
My question was meant as more of a lesson in angles than the actual issue at hand. Looking for the real world methods, tips, and tricks.
Old 08-20-2011, 10:50 PM   #42
Rewards Points: 518
When you guys say scribe are you talking about simply tracing the outline onto the brace or are you using the true method of scribing with a compass?
Old 08-20-2011, 11:23 PM   #43
Rewards Points: 506
Pencil tracing for me.
Old 08-21-2011, 05:33 AM   #44
N0c7, just install a L brace in the corner of the gate in your picture.
One will do but you could do all of the corners if you think it would look better.
Old 08-21-2011, 05:51 AM   #45
Framing Contractor
OMG!!!! How many times do I have to tell you to give the measurements. You will not get any real world methods...tips...or tricks without giving the measurements. If you don't understand that, how are you going to understand any explanations?
What are the measurements of the gate?????
Joe Carola
45 deg angles on the 1 side of a 1xX amakarevic Carpentry 3 01-29-2011 05:11 PM
measuring angles - flooring felicity7 Flooring 3 12-29-2010 06:33 AM
Need some quick help with coffin angles. DangerMouse Building & Construction 6 01-27-2010 03:40 PM
Gable roof angles Enok Building & Construction 2 11-23-2007 08:49 PM
Determining Tonage Rze HVAC 2 10-17-2007 04:21 PM
