Help Determining Angles - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-18-2011, 10:02 PM   #16
Framing Contractor
Originally Posted by n0c7 View Post
Is there a tool that can be inserted into the corner to determine the angle aside from just eyeballing, tracing, or calculating with math?
Any angle can be determined. You just have to give the exact measurements. But for what you are doing,...just scribe the brace on the gate...that will give you the exact angle you need...
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-19-2011, 06:20 AM   #17
kwikfishron's Avatar
Rewards Points: 84
Thatís way too easy and leaves nothing left to debate.
kwikfishron is online now   Reply With Quote
Old 08-19-2011, 07:01 AM   #18
Rewards Points: 506
Originally Posted by kwikfishron
...leaves nothing left to debate.
At the hinge end of the gate, should the angle brace be at the top or the bottom?
jlmran is offline   Reply With Quote
Old 08-19-2011, 07:11 AM   #19
Rewards Points: 84
The bottom but what does that have to do with finding the angle.
Old 08-19-2011, 07:39 AM   #20
Rewards Points: 506
The angle is not a debateable topic...it is what it is. How to FIND the angle could be debated.
Old 08-19-2011, 07:51 AM   #21
Rewards Points: 5,336
This is a public forum, the day of the week is a debatable subject.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Willie T (08-19-2011)
Old 08-19-2011, 07:58 AM   #22
Rewards Points: 506
True...
Old 08-19-2011, 08:04 AM   #23
True...
No, it's not.
Ron
B. Franklin 1759
Old 08-19-2011, 10:54 AM   #24
Rewards Points: 518
n0c7 is offline   Reply With Quote
Old 08-19-2011, 10:55 AM   #25
Rewards Points: 518
Thanks for asking, that was another question I had.
Old 08-19-2011, 10:57 AM   #26
Rewards Points: 518
Right, that's the easiest way. I guess my question goes beyond a simple gate for other spots where it's not easy to scribe the brace or other work from behind.
Old 08-19-2011, 11:08 AM   #27
cut the board a few inches longer than you need....hold the board in place and sqruibe(sp)it in place...use a chop saw.gee wizz
Marbledust is offline   Reply With Quote
Old 08-19-2011, 11:59 AM   #28
What you would do is take into account each individual circumstance and come up with a solution on a case by base basis.
I'm a little confused, now that I see the picture of the gate. I don't know how a thin guide wire and a turn buckle will be more obtrusive then a thick diagonal piece of wood (or 2). From a design standpoint in a deck railing with only horizontals and verticals I would minimize the diagonal visuals.
But, it's your deck.
Ron
B. Franklin 1759
Old 08-19-2011, 12:40 PM   #29
Framing Contractor
No problem...all you need is the height...width and calculator. It's that simple. I asked you before what the measurements are. If you don't tell us... you'll never get your answer.
Joe Carola
Old 08-19-2011, 01:01 PM   #30
Experienced
Jackofall1's Avatar
I don't need the corner-to-corner...do you?
Just wanted to see if things were square with the corner to corner measure.
Mark
45 deg angles on the 1 side of a 1xX amakarevic Carpentry 3 01-29-2011 06:11 PM
measuring angles - flooring felicity7 Flooring 3 12-29-2010 07:33 AM
Need some quick help with coffin angles. DangerMouse Building & Construction 6 01-27-2010 04:40 PM
Gable roof angles Enok Building & Construction 2 11-23-2007 09:49 PM
Determining Tonage Rze HVAC 2 10-17-2007 05:21 PM
