-   -   Help determining angles (http://www.diychatroom.com/f14/help-determining-angles-114363/)
n0c7 08-17-2011 03:18 PM
I want to install a diagonal brace on my fence gate. I'm not very good at determining angles. The two corners that it will meet are 90 degrees inside. What type of tool or method can I use to to mark this on my brace?
Jackofall1 08-17-2011 04:41 PM
If it's truly vertical why are there angles, are you putting in a cross brace?
You could always hold the board up to the gate and transpose some marks on it, then use a framing square to ensure a 90* cut based on your (2) outside marks.
Mark
n0c7 08-17-2011 07:01 PM
Mark
I apologize - I meant a diagonal brace.
Joe Carola 08-17-2011 10:09 PM
Is the gate built yet?
Ron6519 08-17-2011 10:30 PM
Can you post a photo of the gate? How it's cut and installed depends on the gate's conctruction. Sometimes you inset it into the frame, sometimes you attach it to the frame.
Sometimes you can use a turnbuckle with an adjustable nut to keep it square.
n0c7 08-18-2011 09:51 AM
Yes it is.
n0c7 08-18-2011 09:53 AM
It will be inserted into the frame. I'll take a picture in the evening. I want to use a wooden brace in this situation as a turnbuckle will be unsightly with the style.
bob22 08-18-2011 01:03 PM
My assumption is the gate is a rectangle so a diagonal's angle would be 45 degrees to the horiz or vertical planes.
Jackofall1 08-18-2011 01:06 PM
You might want to rethink that, your statement would only be true if the gate was square. The total of the (2) cuts will equal 90*, but it may be 50* and 40* cuts.
Mark
bob22 08-18-2011 01:12 PM
Jack, point well taken. I sit corrected.
n0c7 08-18-2011 03:49 PM
Is there a tool that can be inserted into the corner to determine the angle aside from just eyeballing, tracing, or calculating with math?
Ron6519 08-18-2011 04:04 PM
Easy to use a bevel guage and a protractor. Open the bevel guage to the 2 sides and transfere it to a piece of paper. Take the protractor and measue the angle.
If the frame of the gate is a rectangle, the brace will go corner to corner, so you would need to know the angle corner to corner and the distance between them to cut a snug brace.
Pull a line corner to corner and bevel guage the side to string angle(measure the alternate interior angles) on both sides(they should be the same). Then measure the distance, corner to corner.
jlmran 08-18-2011 05:01 PM
If the math is uncertain for you then you could post the gate measurements here and many folks would provide the correct angles and lengths.
Jackofall1 08-18-2011 06:35 PM
Just need the inside (where the brace is intended to fit) width, height and corner to corner.
Mark
jlmran 08-18-2011 07:24 PM
Mark
I don't need the corner-to-corner...do you? :)
