Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-07-2009, 11:07 PM   #1
Help design plywood box
I need to build a rectangular plywood box. The dimensions will be something like 12"x12"x48". One of the ends needs to be capped, but I could cap both ends. I was thinking about running 2x4's along the inside vertically and just nailing the plywood to them. I would then run small blocking perpendicular to the studs. This seems like a little overkill though. It will be used to support about 25 lbs.
pomelo is offline   Reply With Quote
Old 09-08-2009, 01:17 AM   #2
Agreed, 2x4 is too much, probably better using 2x2 rather than the 2x4 to lighten it up. Would suggest to consider to glue and screw it together than than nailing for more rigidity.
More On This Topic
This metal frame is called the queen excluder. That makes the queen stay only in this chamber brood. She cannot come up into the rest of the bee hive. As you saw, we already saw brood on the second and third supers but that was because this device was... Read More »
OK, I am prying the box up. There is a queen excluder you will notice. The idea is we have the supers on top for the honey production. But we want the queen and the brood to be down in the lower part of the hive. So we have the queen excluder and these... Read More »
Hi I'm Karen for Expert Village now let's do the beehive (hand motions) here's the beehive but where's the bees inside the hive where no nobody sees watch them come out come out of the hive one two three four five zzzzzz. These I like to put together... Read More »
How to Construct a Bee Hive
How to Construct a Bee Hive by Expert Village
This is a bee hive. It’s composed by a floor, a brood chamber—these are called supers, too. The super in the bottom is used for the brood chamber, for the queen to lay eggs, and a top. This brood chamber has frames- 1,2,3,4,5,6,7,8- with wax... Read More »
Now these beehives are here in the orange groves. The orange groves are blooming they have a few supers on them already. You see a number of boxes here depending on how strong they are and how much honey is in the hive. I haven't added any boxes here for... Read More »
Tiling - Gap in plywood (sub)floor mcg Remodeling 5 01-15-2009 05:21 PM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 11 07-13-2008 10:04 PM
Removing kitchen tile with plywood under it ediconu Flooring 4 08-26-2007 09:48 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
