Help Advice Framing/Flooring - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-03-2010, 03:10 PM   #1
Question
Howdy,
I have had a water problem on a building because of improperly install deck. No flashing, ledger boards nailed onto vinyl siding,etc. Decks have been disconnected from house. Wall and door framing has been gutted. I found rotten flooring and floor joists. I ripped out floor joists in this area and cut floor back to solid wood. The floor is kind of wavey and 3-1/4" to 3-1/2" thick with the follow layers from bottom to top: 2-layers of 1" pine board, 1-layer of 3/4" hardwood flooring, and 2-layers of 1/4" lauan. I cannot afford to rip out everything at this time. Should I lay down 1-2 layers of 3/4" decking on new joists and install my framing for outside wall and door on top of this? If I ripout everything of old flooring in the future I did'nt want to have to worry about all those layers under new framing. I hope this gives enough information. PS this house was built in late 1800 to 1900.
Thanks Ed
willworkforfood is offline   Reply With Quote
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Advice for adding sump pit/pump pkovo Plumbing 9 09-20-2009 07:26 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 11:51 AM
I need advice on a flat roof Krissy Roofing/Siding 10 12-27-2007 01:55 PM
