Heavy Duty Garage Shelving Suggestions - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-16-2007, 01:35 PM   #1
Heavy duty garage shelving suggestions
I'm thinking of replacing my mish-mash of different garage shelving with more permanent, sturdy stuff like this:
I like to store my mower under the last set of shelves I currently have. They are bracket shelves so the brace on the wall instead of the floor like the picture above. This allows me to slip the mower under there with no problem.
I'm thinking of a modification to the above picture using a similar method that the brackets use but instead us 2x4 like this:
Does anyone see a problem with this or any caveats I need to consider?
feign3 is offline   Reply With Quote
Old 09-20-2007, 11:07 PM   #2
Extreme DIY'r Adk's, NY
Rewards Points: 254
I built some in my last house basement almost exactly like that. I measured and cut the red gussets after the shelves were up (leveling the shelves as I went. I used double angle cuts on both ends so on the bottom of the gusset... half the gusset rested on the shelf, and half against a stud. Then on the top of the gussets, half against the front board, half against the shelf plywood. Once they're all tied together and mounted to studs they are very strong as a system. I could hang off of them @ 190 lbs.
crecore is offline   Reply With Quote
Plans for a garage loft (large set of shelving) paul_2 Carpentry 10 08-16-2010 08:06 PM
Garage drywall painting haylo75 Painting 18 11-12-2007 09:13 PM
Crazy Garage Extension, Building over blacktop?!?! commissure General DIY Discussions 4 09-13-2007 12:09 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
