-   -   Heading off roof rafters for chimney pipe. (http://www.diychatroom.com/f14/heading-off-roof-rafters-chimney-pipe-30778/)
jrcurto 10-28-2008 11:03 AM
I am assuming I can approach a roof opening for a chimney pipe installation as I would a skylight. I am up on the clearance and chimney requirements but I have to make room in the attic and roof to run it. This is Simpson Duravent 6" triple wall which has a 10" OD. The chimney will pass through the attic via the 14.5" support box but does not clear the ceiling joist and roof rafter above. This is a single story, corner installation from the den below, through the ceiling, about three feet of attic space and through the roof Can I just head these off and frame the opening as needed? Thanks, Jim.
Maintenance 6 10-29-2008 06:32 AM
You can cut them and head them off, but you should double up the rafters and joists on both ends of your new header.
Termite 10-29-2008 07:58 AM
Very true. Doubling the ajacent rafters is a very important step.
Also, use joist hangers on the cut rafter's attachment to the header.
jrcurto 10-29-2008 12:18 PM
Thanks guys, I am doubling up and proceeding on the rafters. Ceiling is done. I may be cutting in the ceiling support box later. Attic is chilly, snow flurries already today!
buletbob 10-29-2008 12:25 PM
Agree! good advice
