Header Size For 12' Opening (not Load Bearing)? - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-07-2008, 12:29 PM   #1
Header size for 12' opening (not load bearing)?
I'm putting in a large(12' wide), but short (5') closet. I want to build an opening 12' wide to put the closet doors on. What size header is appropriate for this?
Thanks in advance!
DIYMom2 is offline   Reply With Quote
Old 09-07-2008, 04:07 PM   #2
Registered User
Termite's Avatar
Even though it is not load bearing, I'd go with a double 2x10. You might be able to get away with less, but I wouldn't, given the size of the opening.
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
Non load bearing header Help! rockdog20 Building & Construction 10 10-22-2007 11:04 AM
Header size for wall opening firebirdbd Building & Construction 1 08-07-2007 05:11 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 07:37 AM
moving another load bearing nailfun Carpentry 2 02-20-2007 08:10 AM
