Header Plate - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-10-2011, 10:02 AM   #1
header plate
Hi there im new here so hello everyone , my question is am i aloud to put a 2x6 plate on my header before i install it. so the 2x6 plate is acually sitting on the cripple. I dont know if that is to code or not?
jamiesch is offline   Reply With Quote
Old 02-10-2011, 10:07 AM   #2
Registered User
Termite's Avatar
If you're talking about laying a flat 2x6 flat on top of the trimmers and then your double 2x header on top of the plate....
I doubt anyone will find anything illegal about doing it. It is an unnecessary waste of lumber however, unless some unusual circumstance warrants it.
Old 02-10-2011, 08:25 PM   #3
Registered User
Rewards Points: 5,218
Standard practice here when using double 2x's, or a 4x for a header-flush out, foam board inside later (when window is not dropped). Gives a nailing surface for drywall and window head trim (casing), unless thicker trim.
Gary
Gary in WA is online now   Reply With Quote
Garage Header rwbil Building & Construction 11 09-16-2010 12:50 PM
Questions on tying 6x8 exposed header to top plate EDI Remodeling 4 06-03-2010 09:27 PM
Replacing Section of Sole Plate RM575 Carpentry 3 03-28-2010 10:31 AM
Top plate over header? zenman Building & Construction 6 08-05-2009 01:04 PM
Moving Header Supports Star Building & Construction 3 09-25-2005 01:50 AM
