Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-13-2008, 08:48 AM   #1
Header for O/H Door in Shed
I am building an 8X12 shed (live in central NJ); 7.5/12 roof; 2X4 rafters and joists.
At one end (the 8 ft side), I plan to install a 5ft wide and 6 ft tall overhead door.
Please advise:
1. Size of the header;
2. Size of ridge board I should use.
Thank you.
Burat is offline   Reply With Quote
Old 07-13-2008, 08:49 AM   #2
Also, what thickness sheathing should I use for the roof, walls?
Old 07-13-2008, 09:55 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
For a shed I would go with 2x6 Ridge and 2x6 Header, if you are running a double top plate then you can cut the lower top plate to accommodate the 2x6 header if the height is compromised. Roof and wall sheathing go with 1/2" BOB.
Old 07-13-2008, 11:37 AM   #4
Moderator
Termite's Avatar
Bob's right. There is very little structural load in a shed that small. 2x6 will cover everything. 7/16" OSB or plywood will be just fine for walls and roof sheathing.
Old 07-13-2008, 03:46 PM   #5
Gentlemen: thank you.
Old 07-14-2008, 05:15 PM   #6
buletbob's Avatar
your quiet welcome
Detached shed/shop rewire gtmatt Electrical 7 05-24-2008 10:40 AM
Garage Header Insight red3908v Building & Construction 4 04-27-2008 09:55 AM
running uf to shed bobo60 Electrical 12 04-20-2008 02:41 PM
Shed Wiring bcdal Electrical 12 03-26-2008 05:51 PM
Moving Header Supports Star Building & Construction 3 09-25-2005 01:50 AM
