Header Or No - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-06-2011, 08:04 PM   #1
Experienced
Naz1298's Avatar
Header or no
So if we take out this doorway and widen it 12" on each side, do we need to keep the header or will the top plate hold?
Naz1298 is offline   Reply With Quote
Old 04-06-2011, 08:20 PM   #2
Rewards Points: 1,016
If you widen the opening, yes, you will need to put in a new wider header to provide proper support.
Old 04-07-2011, 09:51 AM   #3
Experienced
Naz1298's Avatar
Dies it still need to be a 12" or could we make it 6" or so
Old 04-07-2011, 11:08 AM   #4
Registered User
Termite's Avatar
The header was presumably sized based on the imposed loads. Widening the opening and then installing a header half the depth of the former header would not likely be a wise move.
The only way to know for sure if you can get by with a smaller header dimension would be to have an engineer run the calculations for you.
Old 04-08-2011, 12:22 AM   #5
Master of none
As KCT said, do not reduce the size of the header. In the picture, it looks like that wall is a bearing wall so common sense dictates that you need the header. For a difference of $4.00 or so in material don't even think about weakening the support.
handy andy is offline   Reply With Quote
Old 04-08-2011, 11:48 PM   #6
Registered User
Rewards Points: 526
Does the exposed beam running perpendicular to the closet holding the rafters up extend through the closet?
An attic picture from behind the closet side toward the cathedral ceiling would solve it......
Gary
Old 04-09-2011, 12:10 AM   #7
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
Good god it looks like a lot of wasted wood in the framing of that house if the little bit of what we see is indicative.
Gary, can you think of any possible likely scenarios that would lead one to think that a header of that size would be needed for a door that small that is directly under an exterior wall like this one?
It is obviously not a second living space above.
Andy.
AndyGump is offline   Reply With Quote
Old 04-09-2011, 05:21 PM   #8
Registered User
Rewards Points: 526
My first impression is the framer used a 2x12 for all the doors and windows, a common usage to have them a uniform height (SOP when headers cut on lumber pile). Second thought is if the beam stopped at the closet wall, I guessing it does, then the closet ceiling is only 97" high (notice the insulation) and the back wall of the closet continues up for a second floor behind the cathedral ceiling area. I have framed many houses this way. Though I would have made the exterior closet door wall (insulated), a rake wall without a rafter on it as by the single top plate. The doubled studs abutting the beam post, and the kings, and the cripples tell me there may be some weight bearing above the door wall. Hence the required picture..... So no second floor at all, what does the closet/ceiling roof look like, Andy? Why the insulation? Did I miss a picture?
OP, I'd at least add a positive tie at post/beam.
Gary
Support for Header Shakemsam Building & Construction 4 12-04-2010 03:38 PM
Garage Header rwbil Building & Construction 11 09-16-2010 11:50 AM
Raise header of house wall plus add more header capslock Building & Construction 22 02-01-2010 09:13 PM
Cripple studs below a header mercy Building & Construction 3 01-20-2010 03:20 PM
Moving Header Supports Star Building & Construction 3 09-25-2005 12:50 AM
