HD Pre Cut Counter Tops - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-02-2014, 10:53 AM   #1
Rewards Points: 2,038
HD pre cut counter tops
My kitchen counter tops are pretty awful. Grungy looking. I won't be replacing the Formica cabinets any time within the next few yrs. Maybe never. So I've decided to get new countertops since the cabinets area is small it won't cost much.
At HD, in the back, I saw precut counters, with the angle for the corner. They're affordable but I wonder about the durability. I don't want to waste money if they won't hold up. I also don't want to put a more valuable counter on Formica cabinets.
Thanks for any opinions.
Startingover is offline   Reply With Quote
Old 02-02-2014, 11:00 AM   #2
Rewards Points: 12,876
I've never had any problems with them.
Same as any counter top, do not set something hot on them.
Startingover (02-02-2014)
Old 02-02-2014, 11:50 AM   #3
chitownken's Avatar
Rewards Points: 510
Have had one of them in my laundry room for 11 years now with no issues.
chitownken is offline   Reply With Quote
The Following User Says Thank You to chitownken For This Useful Post:
Old 02-02-2014, 09:19 PM   #4
Rewards Points: 166
check MENARDS. they have those tops, but IMO much nicer patterns. there is one that looks a lot like nice granite.
Fix'n it is offline   Reply With Quote
Old 02-02-2014, 09:24 PM   #5
kwikfishron's Avatar
Rewards Points: 90
Make sure "your" inside corner really is 90 deg before you buy.
kwikfishron is offline   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
Live_Oak (02-05-2014), oh'mike (02-03-2014)
Old 02-02-2014, 10:52 PM   #6
Rewards Points: 3,715
They work. I have used them a few times. You may need to add some ledge strips to the wall to increase the support. This depends on what you find when you pull the old counter top. This tends to be more necessary with corner cabinets and not so much with blind bases.
There is no such thing. Close is the best you will ever do and for the the rest there is caulk.
Colbyt is offline   Reply With Quote
Old 02-02-2014, 11:12 PM   #7
Rewards Points: 166
yeah. but they can always take it back.
Old 02-03-2014, 05:56 AM   #8
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
90 Deg Corner
If your Kitchen corner is not 90 Deg e.g. 92 Deg, then HD has no obligation to give any refund. The advice to check your existing corner was good.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-03-2014, 09:21 AM   #9
AHH, SPANS!!!
Rewards Points: 1,166
cardboard makes a good template to check the walls corners with...
hand drive is offline   Reply With Quote
Old 02-03-2014, 08:45 PM   #10
Professional
TotalHomeworx's Avatar
There are a lot of counter top companies that supply tops and will come out and measure for you and install. Free quotes. There is more to it then if the corner is out (it is out, they all are) you get what you pay for with HD. I find the tops are warped a bit so the 90s do not line up properly.
TotalHomeworx is offline   Reply With Quote
Old 02-03-2014, 09:30 PM   #11
Rewards Points: 166
i bought 2 tops. they took them back with no issues what so ever.
Laminate counter tops, can they be joined? Strife_Design Kitchen & Bath Remodeling 6 07-05-2013 12:12 PM
What is the standard depth of kitchen counter tops RobertN Carpentry 3 10-29-2010 11:28 AM
Corian or Granite counter tops Jms92 General DIY Discussions 21 04-17-2010 07:18 PM
concrete counter tops rwongrey Remodeling 10 07-13-2009 02:25 PM
attaching countertop analogmusicman General DIY Discussions 22 08-10-2008 12:53 PM
