HD Lumber Warping ... This Is Ridiculous - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-22-2012, 01:47 AM   #1
Rewards Points: 1,062
Question
HD lumber warping ... this is ridiculous
i have very rigorous acceptance standards when buying lumber. i reject at the slightest imperfection and my find ratio is somewhere between 10-20% for 2x4s.
but even when i do get 100% straight ones, if i don't use them within ... no kidding, 48 hrs, they get warped out of the acceptable.
i don't store them in any way that can cause warpage, just typically lay them flat on the ground.
what is the deal with this lumber ?? why does it warp so much ?
Old 02-22-2012, 03:32 AM   #2
Stay-at-home GC
Store it off the ground with blocks, chocks or sleepers depending on where you grew up. Bonus points if you put down Visqueen first. Then cover it with Visqueen. Store it out of direct sunlight.
It warps because it has high moisture content.
Wikipedia
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 02-22-2012, 06:30 AM   #3
Buy Kiln Dried (KD) lumber, often not available at big box.
The Following 2 Users Say Thank You to Just Bill For This Useful Post:
amakarevic (02-22-2012), Hardway (02-26-2012)
Old 02-22-2012, 07:01 AM   #4
DIY staff
Rewards Points: 7,174
You bought that lumber from a wet load---Improperly stored or wrapped during shipment--
Take it back--find a dry load in a different store.
Old 02-22-2012, 07:17 AM   #5
Civil Engineer
Rewards Points: 4,782
Consider building using steel studs, no warp.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
chrisBC (02-23-2012)
Old 02-22-2012, 08:20 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I prefer to order all framing lumber from Lumber Yards, rather than Big Box Stores.
- Build Well -
The Following 3 Users Say Thank You to AtlanticWBConst. For This Useful Post:
amakarevic (02-22-2012), chrisBC (02-23-2012), woodworkbykirk (02-22-2012)
Old 02-22-2012, 05:58 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
big box stores keep far less lumber in stock compared to lumber yards. what little good material they do have in stock goes pretty quick as its picked over
keep the straight material for corner studs, king and jack studs.. use the ones with slight crowns for the commons.. for long material for plates simply kerf cut them so you can straighten them easier
the ony other thing i can think is that your not storing it correctly, if you go from one extreme to the total opposite extreme the wood is going to move.. you cant bring wet lumber directly inside to a low humidity space right away and expect it to stay straight. you have to climatize it
besides if you want perfectly straight material your going to have to use either steel stud or pay way more and use timberstrand engineered studs
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Old 02-23-2012, 02:46 AM   #8
Yeah anytime buying lumber at a box store it is usually pretty frustrating trying to pick out the good ones. Lumber yards are better; or as mentioned, steel framing really does have its benefits.
chrisBC is offline   Reply With Quote
Old 02-23-2012, 07:44 PM   #9
then again, it also has its negatives. cant gun nail trim to it to hold... cant hang anything heavy on the wall without putting plywood backing in
amakarevic (02-23-2012)
Old 02-23-2012, 08:02 PM   #10
i like to build with organic materials
Old 02-23-2012, 08:39 PM   #11
Yes, this is true-especially if you are doing reno's and will have to open up the wall to put in backing, much more of a PITA than redoing a kitchen in a wood frame building.
Old 02-23-2012, 09:42 PM   #12
Rewards Points: 506
Steel is less organic than wood? Both come from the earth and both receive significant human manipulation before YOU get it.
The organic characteristic of the wood is what causes it to warp.
jlmran is offline   Reply With Quote
The Following User Says Thank You to jlmran For This Useful Post:
woodworkbykirk (02-24-2012)
Old 02-24-2012, 12:16 AM   #13
well, all building material comes from the earth. i'm not aware of any sent to us by extraterrestrials ...
Old 02-24-2012, 09:51 AM   #14
Rewards Points: 242
I've had the same problem. I can't tell how much warp you are talking about, but in the future, I won't be buying more than I can use relatively quickly. I bought better grade...the best they had at Lowes, and it warped standing in a corner in my garage, waiting to be used. Corner is near my garage door and temperatures varied during storage from winter nights to the 50's and 60's during the day as my garage isn't heated.
However, I was able to make it work...so, lesson learned.
Ed911 is offline   Reply With Quote
Old 02-24-2012, 11:01 AM   #15
Rewards Points: 304
Problems I've found picking over wood at my local big box store is it's often times hard to get at the good/straight pieces, since they're usually in the largely undisturbed piles. A nice nearly fresh pallet is usually the best bet. Since sometimes the wood is on higher shelves, it's a big pita to get to, and many of the reachable boards have been moved around and put back not stacked at all in any order, causing them to warp even more. What can you do..
As others said, sometimes they'll have several pallets that are damp/soaking wet, which I'm sure doesn't help the wood. I just avoid those.
NewHomeDIYGuy is offline   Reply With Quote
Tags
warped
Lumber Liquidators Bud Cline Flooring 11 10-28-2011 02:00 PM
Lumber Yard vs. Box Store? cbzdel Building & Construction 8 06-30-2011 11:49 PM
Lumber Quality Giles General DIY Discussions 1 01-15-2011 04:10 PM
Cheapest place to buy lumber - home improvement store or lumber supplier? J S Machine General DIY Discussions 23 01-13-2011 05:17 PM
Help! My pressure treated lumber is warping! jrepp Building & Construction 5 10-31-2007 03:15 PM
