Hardwood Tongue Is Splitting With Nailer - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-20-2009, 06:26 PM   #1
hardwood tongue is splitting with nailer
I am using a pneumatic nailer with 2in cleat nails, and the tongue is sometimes splitting when I put the fastener in. The compressor is set at 90 psi as stated by the tool. What is causing the splitting?
thanks
atomilano is offline   Reply With Quote
Old 03-20-2009, 07:12 PM   #2
Is this on flooring, or tongue and groove planking?
sausagefingers is offline   Reply With Quote
Old 03-20-2009, 07:14 PM   #3
Are these nails recommended by the floor manufacturer? Usually the directions will specify the proper nails to use!
Hope you didn't get poor advice from the guy on the sales counter!
Old 03-20-2009, 07:59 PM   #4
What type of wood?
jerryh3 is offline   Reply With Quote
Old 03-20-2009, 09:35 PM   #5
The salesman recommended the 2in cleat nails. The wood is a 3/4 in x 5in cikel Tigerwood hardwood. We put in 3 rows and everyone has split.
Old 03-20-2009, 11:12 PM   #6
I suspect that you are hitting the nailer too hard. Try lightening up on it. Just a small firm tap is all you need with a pneumatic flooring nailer. Might want to try turning the air down if this doesn't work.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 03-20-2009, 11:16 PM   #7
Sales people can be mistaken! He may have had good results from another type of wood! Whereas, it appears that the gauge is too large for the type of wood that you have.
Flooring usually comes with a flyer with install instruction and 1-800 number that you can call for assistance.
Old 03-21-2009, 10:23 AM   #8
We did check with the manufacturer and it does state we should use the 2in cleats. I am trying it now with turning down the psi to about 75 and hitting it not as hard. Thanks alot. I will see what happens.
Old 03-21-2009, 10:27 AM   #9
the Musigician
DangerMouse's Avatar
perhaps filing the points of the nails would help? or predrill.....
DM
Old 03-21-2009, 04:43 PM   #10
From what I've seen, hitting a pneumatic flooring nailer too hard will split the tongues. Also, do you have the gun adjusted so it places the nails properly. There is some adjustment with them. I would have guessed that with the flooring cleats...they are pretty much good with any tongue and groove flooring.
Old 05-04-2009, 09:05 AM   #11
Another possible reason
Also check to see that your nailer has the correct "seat" installed. There is a pad on the bottom of the nailer that gives you the correct height for the thickness of your board. If the pad is too thin, you can be putting pressure on the tongue with the nailer.
gfelix1909 is offline   Reply With Quote
Hardwood Nailer and Compressor - HorsePower/PSI or SCFM? hwood Flooring 3 03-04-2009 04:11 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
Recommedation for Removing Tongue on Hardwood Plank. anthony9887 Flooring 10 07-13-2008 06:44 PM
Hardwood Nailer suggestions LaurynJohnny Flooring 2 11-26-2007 06:06 PM
