Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-22-2011, 10:33 AM   #1
Hardwood Flooring Identification
Hi there guys, its my first post, hoping if you can help
I have just moved into my new house and ripped out the old carpet and found hardwood parquet flooring underneath!
only problem is the chimney breasts have been removed, so there's a cement rectangle on one end of the floor. I'm thinking to restore the wood, and fill in the gaps where the chimney was but i need a hand identifying the type of wood i have.
any help would be appreciated, thanks a bunch!
oh and would be helpful to have your opinions on whether it is worth reviving or not!
thanks!
Hardwood Flooring Identification-1.jpg   Hardwood Flooring Identification-2.jpg   Hardwood Flooring Identification-3.jpg
dav_Cam3 is offline   Reply With Quote
Old 08-22-2011, 10:37 AM   #2
Experienced
Jackofall1's Avatar
Hello and welcome Dave to the best darn DIY'r site on the web.
Looking at that grain it appears to be pine, but I am by no means a professional on the subject matter.
How soft is the wood, can it be marked with a fingernail?
Mark
Old 08-22-2011, 10:46 AM   #3
when i press my fingernail into the wood it does make somewhat of a marking, but some effort is needed.
thanks for the quick reply Jack
Old 08-22-2011, 11:00 AM   #4
Civil Engineer
Based on the hardness test, and the side shot, I am going with oak.
Old 08-22-2011, 02:46 PM   #5
SteelToes's Avatar
Pine.
SteelToes is offline   Reply With Quote
Old 08-22-2011, 03:17 PM   #6
Experienced
Jackofall1's Avatar
Originally Posted by SteelToes View Post
Pine.
Old dry pine.
Mark
Old 08-23-2011, 07:18 AM   #7
gravity always wins
I'm going with Red Fir.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
oh'mike (08-23-2011)
Old 08-23-2011, 07:34 AM   #8
Super Moderator
Fir tongue and groove porch decking---you should still be able to buy that.
Old 08-23-2011, 03:56 PM   #9
i was thinking Douglas Fir...
1910NE is offline   Reply With Quote
The Following User Says Thank You to 1910NE For This Useful Post:
Ron6519 (08-23-2011)
Old 08-23-2011, 06:28 PM   #10
Stairguy
that is CVG (clear vertical grain) fir
Millertyme is offline   Reply With Quote
The Following User Says Thank You to Millertyme For This Useful Post:
BigJim (08-23-2011)
Old 08-26-2011, 07:05 PM   #11
Ditto Millertyme's response. That is definitely CVG Douglas fir, and you can find that online.
Altruwood is offline   Reply With Quote
Old 09-12-2011, 09:52 AM   #12
Hi Guys!
thanks for all ur replies, thought id keep you updated
i had a few blocks in the hallway that i removed and fit them into the living room where the chimney breasts used to be.
there was a gap down the middle of the room, done some patch up work with a new pine wood.
now i need to get the stains to match. anybody recommend any tips/stain colours that will go?
its getting there, really pleased by the way it looks so far
just hope i havent ruined it by taking the easy way out and adding new wood..
Hardwood Flooring Identification-hounslow-20110907-00020.jpg   Hardwood Flooring Identification-hounslow-20110907-00021-1-.jpg
Old 09-12-2011, 02:01 PM   #13
I think you did a nice job on it, but I am not sure if that is ever going to match when you stain it.
I would think you can buy wood that matches a lot closer and put that in.
I had an area in a house once, where I had two different floors meeting. I tore out two strips and laid in a decorative terra cotta tile design in place of the wood. It provided a nice break and an interesting way to transition, many people commented positively on it.
This way it broke it up and looked intentional as opposed to repaired.
I am not sure if you can tile that section and have it look right, depends on where those two sections are.
Otherwise, I would get some wood to match better, because I think you are always going to be sorry you didn't.
I think the key is to get the wood to match closer in color before you stain it. A trick I have also used to blend wood colors is to use very strong tea or coffee mixed with water to stain it before the stain. You have to really soak it in there and work to get it to match. Then you have to make sure the wood is completely dry before you put the stain over it. It requires a little more art than science.
oldhouseguy is offline   Reply With Quote
Old 09-12-2011, 05:53 PM   #14
Super Moderator
Track down some fir--the color on the pine you chose is to yellow---fir is salmon colored--
If you have access to a surface planer you could plane down 2x material if that's all that is available.
Staining pine is not a good idea---especially a mix of old and new.-
Old 09-12-2011, 09:15 PM   #15
Knucklez's Avatar
i have old pine floors and had to replace a board with new pine. when i put the same stain on both boards the colours was HUGE different! so i got a bunch of new pine boards and tested other, darker, stains until i could match my light colour stain on the old board. then i went back and stained the new boards installed on the floor with a darker stain so that when it dried it matched. takes a lot of time, but it can be done.
on the other hand, the location of your new wood is a natural divider between two rooms, so maybe slight difference in shade is not a big deal.
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 06:15 AM
Transition of Hardwood Flooring on Stairs rkirby Flooring 1 02-02-2011 07:06 PM
Hardwood flooring cupping Brian Lewis Flooring 14 12-06-2010 03:19 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
What type of Hardwood Flooring for Concrete Slab? talk show host Flooring 5 01-22-2010 09:37 AM
