Hardiplank Siding - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-13-2011, 10:38 AM   #1
hardiplank siding
I am going to start replacing the old LP siding on my house with Hardipank and I noticed some contractors have used a type of flashing behind the seams where the joints fall to avoid caulking. What kind of flashing is this?
Tried the pro desk at HD and Lowes but no one seems to know.
jsmith730 is offline   Reply With Quote
Old 08-13-2011, 10:45 AM   #2
Framing Contractor
That's because they have no ides what they are doing. Go to a real lumberyard and ask them. Usually step flashing is fine.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-14-2011, 10:40 PM   #3
remodeling pro
I believe he is talking about the butt seams on long courses, not flashing down an abutting wall.
The "flashing" is called a "spline" and is nothing more than a piece of waterproof flat material 2 1/2 to 3" wide, centered under the seam so it that will direct water out of the bottom of the lap. The traditional material was 30lb felt, but I like to use scraps of coil stock to cut them from.
troubleseeker is offline   Reply With Quote
Old 08-14-2011, 10:52 PM   #4
Rewards Points: 150
We use a product called Fortifiber. It comes to us in a 12" wide roll. You can cut what you need with a utility knife which for this application would be 3" prox. It's real quick to use, self adhesive so it stays in place until the siding goes over it. We blind nail most everything here so it also gets a nail in it thru the siding. Here's the data on it:
http://www.fortifiber.com/fortiflash.html
TrapperL is offline   Reply With Quote
HardiPlank Siding - too Heavy? YukonDave Building & Construction 9 02-15-2014 01:52 PM
Hardiplank siding project - quotes ATL2008 Remodeling 7 06-20-2008 12:10 PM
Hardiplank siding Clutchcargo Building & Construction 15 04-04-2008 05:17 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
