HardieTrim Rejecting 15 Ga Dewalt Nailer - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-14-2011, 04:19 AM   #1
cortell's Avatar
Rewards Points: 504
HardieTrim rejecting 15 ga Dewalt nailer
I'm trying to install HardieTrim using my Dewalt 15 ga finishing nailer. HardieTrim specs calls for 16 ga. I had hoped 15 ga is close enough. Problem is that about every other nail fails to drive into the trim. I'm spending more time dejaming the nailer than I am installing trim! The compressor is plenty strong and set at more than enough pressure. I'm using 2" finishing nails, as prescribed by Hardie, and the nails are designed for use with this nailer.
What do you guys think? Can the 1 gauge difference explain the jamming? Do I go rent/buy a 16 ga nailer, or is there something I may be doing wrong using the 15 ga one? I've used it before to install wood trim with no problems.
cortell is offline   Reply With Quote
Old 09-14-2011, 08:32 AM   #2
Rewards Points: 5,336
Are you sure finish nails are appropriate for this? I've never used headless nails for siding.
Ron
B. Franklin 1759
Old 09-14-2011, 08:50 AM   #3
cortell's Avatar
Rewards Points: 504
Yep. The following document from the Hardie company says so. http://www.jameshardie.com/pdf/best-...anada-trim.pdf
Old 09-14-2011, 09:02 AM   #4
kwikfishron's Avatar
Rewards Points: 186
Harbor Freight Nails???
kwikfishron is offline   Reply With Quote
Old 09-14-2011, 10:52 AM   #5
Rewards Points: 150
You'll need to either rent or buy the right gun. The DeWalt you have is too weak for the job, it's intended use is for wood trim as are the nails. I would not suggest using a finish nail gun at all. We use a Duo-fast EXT siding gun with cement coated nails. The nails have a head and are 2" long. This model has served us well over the years and failures are just about unheard of, if you intend to buy a gun.
TrapperL is offline   Reply With Quote
The Following User Says Thank You to TrapperL For This Useful Post:
Tom Struble (09-14-2011)
Old 09-14-2011, 03:23 PM   #6
cortell's Avatar
Rewards Points: 504
Thanks, TrapperL. You know, I called the Hardie company and spoke to one of their tech reps. I told him I was using a 15 ga Dewalt finishing nailer and he didn't blink an eye. He said he hadn't heard of 1 ga making a difference when installing the trim. Apparently, you're more in the know than that person was. I'll be renting the type of nailer you recommended. Thanks!
Old 09-14-2011, 05:51 PM   #7
Tom Struble's Avatar
Rewards Points: 2,002
you can buy stainless ring shank siding hand nails,or you can use the new clips system and eliminate many face nails
Tom Struble is offline   Reply With Quote
Old 09-15-2011, 06:56 AM   #8
Rewards Points: 186
I find it interesting that Hardi does not list a RS siding nail as an approved fastener for trim and instead only shows a smooth finish head nail.
I would have a hard time following that spec.
Old 09-24-2011, 07:33 PM   #9
Hi there,
A 16ga nail is actually smaller in diameter that your 15ga and as such should be more likely to bend.
We use 16ga and 15ga often to install interior trim, the last time I had a problem like the one you're describing was when one of our crew bought Bostitch nails for our Porter Cable 15ga guns (wrong angle).
They went in the gun o.k. but every other one jammed or bent...let the counter guy convince him our grey Porter Cables must be a cheap knock off of their Bostitchs and sold him Bostitch nails
ewils91 is offline   Reply With Quote
Old 09-25-2011, 07:07 PM   #10
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
15 gauge nails are actually much stronger than 16 gauge nails. not only that in my experience with dewalt nailers they are extremely prone to misfiring and jamming. also the porter cable nails jamb up guns quite a bit even in the porter cable guns for which they should be less prone to do. on a thick peice of stock such as harti i recommend using swanson pre painted stainless steel hand nails
regarding harti trim, locally its a product that no one uses. its too hard to work with, very prone to snapping and a pain to cut. ive only used it once and hated it. i have worked with harti siding quite a bit, i either use prefinished lodge pole pine trim for wood siding or azec and even a combination of both. far easier to work with and the azec comes in various profiles
woodworkbykirk is offline   Reply With Quote
Old 10-08-2011, 10:16 PM   #11
Rewards Points: 212
I have head the same problem trimming out some columns with hardi. The preasure was not high enough. Make sure you got the propper angle or straight nails in the gun and make sure your preasure is 120. Try it at 120 to make sure it works and turn it down if it wants to shoot too deep, but it will not be too deep if it is 1x hardi. what model gun you got? does it specify a nail to use on the gun?
bluebird5 is offline   Reply With Quote
Dewalt framing nailer leaks air cornick Tools 8 12-11-2009 01:45 PM
15 or 16 gauge nailer for larger MDF Crown Klawman Carpentry 2 11-10-2009 02:16 PM
Hardwood Nailer and Compressor - HorsePower/PSI or SCFM? hwood Flooring 3 03-04-2009 04:11 PM
stupid question about a brad nailer? cyclonic Carpentry 17 08-23-2008 07:55 AM
