Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-17-2011, 12:50 PM   #1
Question
Hanging tv from 1'' knotty pine.
Hi,
I have a 32'' flat screen which weighs about 20-22 lbs and want to hang it from my knotty pine walls which are about 1'' thick. I haven't found any studs but was wondering if I used lag bolts or anchors that would hold 80lbs to hold the mount in place, would it work? Or would my walls come down with the tv? I bought a corner wall mount if that makes any difference.
Thanks,
Mike
Mike7 is offline   Reply With Quote
Old 10-17-2011, 01:10 PM   #2
You need to get into a stud, what do the instructions for the mount say?
josall is offline   Reply With Quote
Old 10-17-2011, 01:17 PM   #3
It says find a stud but i also put up a tv mount with the lag bolts in some drywall without a stud and that thing isnt going anywhere.
Old 10-17-2011, 04:30 PM   #4
I would not personally throw lag bolts into the wall...
If there is not a stud where you want to hang the TV, I bet there is a kit that will span the studs on either side, and allow you to put the TV exactly where you want it. I just googled it and the options seem endless.
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Old 10-17-2011, 04:35 PM   #5
Average Joe/ex-Navy IC3
gregzoll's Avatar
And, do you really believe that. It is going somewhere, just right now it isn't, but give it time, it will fall to the floor.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 10-17-2011, 05:02 PM   #6
You keep on believing that.
You're in the lead for, "Funniest post of the Day".
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
gregzoll (10-17-2011)
Old 10-17-2011, 05:05 PM   #7
Knotty pine walls are installed vertically. Most of the support framing(the studs) are horizontal. The vertical framing members might be 2 feet apart, or more, depending on who put them in.
The horizontal framing should be 16" on center up the wall.
Ron
B. Franklin 1759
Old 10-17-2011, 06:08 PM   #8
ya well, the jerk store called and you have aids.thanks for nothing. i thought i could ask a simple question without being heckled and this is what i get. ill never be back on here again.
I guess it would make no sense answering your question then
forresth is offline   Reply With Quote
Old 10-17-2011, 06:13 PM   #9
journeyman carpenter
woodworkbykirk's Avatar
as the previous poster mentioned, there will be horizontal blocking in the wall for the panelling to be nailed to
also, since the panelling is 1" thick the nails are almost certain to be visable either directly or indirectly ... meaning that you should be able to see the wood filler to hide the nails. this is your ticket to finding solid backing. by no means would i use a toggle bolt to hold a tv. even though they say there rated for 80lb i dont trust them. i always anchor to something solid, you can rig up a peice of pine thats decorative which you can fasten to the wall horizotally which will then give you something anchor your tv bracket to
woodworkbykirk is offline   Reply With Quote
Old 10-17-2011, 06:47 PM   #10
Framing Contractor
So you don't want to do what the instructions tell you to do and your asking this question. What are you asking if you already have your mind made up? Go for it and see what happens.
Joe Carola
Joe Carola is offline   Reply With Quote
knotty pine vaulted ceiling raghib Building & Construction 32 05-09-2012 10:25 AM
Can't find studs behind knotty pine paneling David S General Discussion 15 09-05-2010 06:56 PM
Knotty Pine mgortel Carpentry 5 06-21-2010 09:21 PM
HELP!!! Primed Knotty pine... needs to be unprimed! deke44 Painting 2 06-04-2010 04:44 AM
Cleaning knotty pine t/g boards barks Painting 3 03-22-2005 12:13 AM
