Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-29-2009, 10:48 AM   #1
Jack
Default Hanging doors
I have just re-hung a door. Does anyone know of a difinitive way in which I can work out which hinges to adjust to stop a door self closing?
Jack
Jackamus is offline   Reply With Quote
Old 10-29-2009, 11:03 AM   #2
Not so new
12penny's Avatar
Jack...sounds like the door wasnt hung plumb, in reference to its face. Did you rehang the entire unit or just the door?
Put a level on the door next to the hinges and move the hinges in/out till door is plumb.
12penny is offline   Reply With Quote
Old 10-29-2009, 11:13 AM   #3
Or you can use an old carpenters trick and pull a pin out of one of the hinges, lay it flat on concrete, give it a slight wack with a hammer to put a slight bend in it and reinstall back in the hinge.. Works most of the time..
RTRCon is offline   Reply With Quote
Old 10-29-2009, 11:22 AM   #4
Jack
Thanks for your quick response. I re-hung the door from the left side of the door frame to the righthand side. Assuming you are looking at a closed door that opens towards you; the door can be out of plumb in 3 different ways;
1 The door frame is out of plumb.
2 If one hinge is rebated more than the other.
3 One hinge is sticking out towards you more than the other. Its trying to decide which one. There is a point when the door is in equilibrium at about 18 inches from the closed position. I suspect that the door frame is wrong.
Jack
Old 10-29-2009, 11:26 AM   #5
Jack
RTCON,
Bending hinge pins is cheating!
I will resort to that if after finding that correcting it any other way will make the door look unsightly - uneven door gaps etc.
Jack
Old 10-29-2009, 01:33 PM   #6
Custom Cabinet Maker
NORMALLY if a door swings closed on its own it is out of plumb vertically; IE place the level on the face of the door and you should see which way u need to move it, sounds like you need to move the top of the door out toward you
skymaster is offline   Reply With Quote
Old 10-29-2009, 02:15 PM   #7
Jack
Hi,
You were right the bottom door hinge needed to go closer to the door stop by about 1/8 inch on the door frame. After cutting away more of the frame I tried it with just the bottom screw in the hinge and that was OK. However when I put the other two screws in the hinge it started to close again! I loosened off the top screw and it stopped. Crazy!. Just to see what would happen I loosened off the top hinge screws and then retightened them and the door now stays wherever I put it. I reckon that loosening the top screws allowed the door to 'settle' in some way - I don't know what else it could be. I now have to move the door stop to allow for the new hinge position.
Thanks for your advice.
Best regards.
Jack
Old 10-29-2009, 09:27 PM   #8
Jack: glad you got it fixed, Also nudder trick is take old playing cards and use em fer shims under the hinges works really well. Man here I am talking to myself again!!!!!!!!!!
Jack
Old 10-30-2009, 06:33 AM   #9
Jack
'Fraid so Skymaster!
BTW have you ever been able to sucessfully use a plumb bob? I find them virtually impossible to keep still without banging in nails to tie the string to and hold it still or is there a technique I've missed?
Jack
Old 10-30-2009, 12:07 PM   #10
I do pretty much same thing. One thing to make sure of is to wrap the string aorund the pc you are trying to plumb TO a couple of times then just tack to the back of it. Hmmmm I try in English now LOL LOL
Make the wraps FROM the face so string hangs against it. Also use a real HEAVY plumb bob NOT a chalk line critter. You can get em in box stores, nice big brass with steel tips and use mason line.
Jack to Jack
Old 10-30-2009, 03:01 PM   #11
Jack
Jack to Jack[/quote]
What about the diameter of the plumb bob weight? I supose it is OK for it to rest against whatever it is you are checking provided you make sure there is no friction to hold it out of-line.
I reckon that a 3mm flat steel disc about 100mm in diameter with the line attached trough a hole close to its edge would make a good one and keep the line close.
Jack
Old 10-31-2009, 04:00 PM   #12
Household Handyman
Jackamus: as far as RTRCon's post--I cheat also. Bending one pin is not really cheating to me, bending two or more means it is time to check the door frame about twenty different ways. Jackamus, you re-hung the door from a LH to a RH, which is quite a feat. At least it sounds as if you have found the problem and the solution which is good. I like to use a plumb-bob for hanging new door/door frames myself, but-I use my 6" speed-square to place it 6" away from the actual door frame, and a large numbered 12" scale to read my measurements. An old trick from hanging steel when building buildings. Nowadays, the large numbered scale is good for the old eyes . This series of posts is one reason I recommend this site to people, so much good information for people to learn. Thanks, David
Old 10-31-2009, 05:49 PM   #13
Jack
Hi Thurman,
Thank for your response.
I too like to gather up new information on time old problems.
Changing a door from right to left hand was easy - it just means cutting new rebates for the hinges and door catch plate in the door frame, fixing the old rebates and door catch hole with bits of wood, filling and sanding down.
Is your 'speed' square the same as an English 'Try' square (a steel plade set at right angles into a wooden stock or something else? I am struggling with trying to vsualise how you use a square and plumb line and 12inch rule when setting up a door frame.
I'm a retired technical illustrator and love drawing everything to explain how and why and it is reletively easy for me to do that. What about you?
Jack
More On This Topic
Door handing refers to the way a door opens. Determine the door hand by figuring out whether the door opens inward or outward, and to the left or to the right. You need to know the hand of the door in order to purchase and install the right door hardware... Read More »
Wreaths are a great accent for doors during the holidays as well as year round. Hanging a wreath on an exterior door can be difficult when trying to avoid damaging the door. Look outside of the box for quick fixes to wreath hanging dilemmas. With a few... Read More »
Removing Old Door Trim
Removing Old Door Trim by Expert Village
I’m Lee Wallace. I have a degree in architecture, I have about ten years construction experience in the field, and today we’re going to replace the door trim. The door’s already been replaced and we have this old trim on here, some of... Read More »
My name is Craig Hale. I am an interior decorator and I am helping Expert Village.com today talk about ways to decorate your walls and different types of objects it is decorated with and also how to even arrange them on your wall. So this is what you do... Read More »
On behalf of expertvillage.com, I am Jim Koch and today we are talking about a locksmith would access to your house when you've locked your keys in or lost your keys. We are going to talk a little bit about security and some of the things you can do to... Read More »
Input on which doors to replace interior & exterior door with... tomas21 Carpentry 9 09-14-2009 05:04 PM
Hanging doors bronco2 Remodeling 2 05-04-2009 02:57 AM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 07:04 PM
Hanging doors on drywalled and finished opening dk_99 Building & Construction 9 12-31-2007 11:34 AM
Hanging new interior doors DarenC Remodeling 4 09-02-2007 10:44 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
