Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-10-2011, 12:39 AM   #1
Hanging Cabinets Without Studs
Hanging cabinets in a remodeled office closet. Each cabinet is 42lbs empty, and there are two.
Each 42lb cabinet will hang from two 22" wall mounted and angled furring strips 4.75" below the ceiling (allow for clearance to hang the cabinet from the matching angled furring strip).
Problem is I can only hit 2 of the 3 24in-on-center studs in the closet this way. No top rail, no cross pieces and the center stud will be covered by the cabinet walls, thus unusable.
Can I do this will toggle bolts? How much weight will generic toggle (the ones with the metal wings on a nut) bolts support? How many would I need to support 42lb cabinets, PLUS contents?
Or should I just tear up my freshly painted wall and put a strip of wood across all 3 studs flush with the drywall?
jage is offline   Reply With Quote
Old 10-10-2011, 07:46 AM   #2
Your property or leased/rented??? Are you allowed to do this?? I would not rely on toggle bolts in drywall. Horizontal furring strips screwed to the studs would be my suggestion.
Old 10-10-2011, 08:16 AM   #3
Old School
Willie T's Avatar
Open it up and install enough wood to fully support the cabinets.
Willie T
Old 10-10-2011, 10:44 AM   #4
You are already using French cleats. I would rip a couple of furring strips that are the same depth as your drywall, and then cut out the drywall behind them. Screw those to the studs, and then your French cleats to those furring strips.
1910NE is offline   Reply With Quote
Old 10-11-2011, 12:46 AM   #5
Too Old
They may only be 42lbs now but when you put them on the wall I am sure you will be putting things in them. I would not trust toggle bolts.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 10-11-2011, 04:12 PM   #6
bubbler's Avatar
Wood or metal studs? I'm hearing "office" and 24" OC, makes me wonder if this might be metal...
I don't know if that changes anything though?
bubbler is offline   Reply With Quote
Old 10-12-2011, 09:01 PM   #7
I would screw a sheet of 5/8" plywood over the drywall. Paint he plywood to match the walls and then hang the cabinets on the plywood.
Hanging Kitchen Cabinets RMCarner Interior Decorating 0 02-08-2011 04:11 PM
Hanging Cabinets darenrogers Carpentry 10 11-14-2010 09:08 AM
hanging upper cabinets without studs picsaro Carpentry 8 04-02-2010 10:28 AM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 02:03 PM
Hanging Kitchen Cabinets from soffit...no backwall ronp Carpentry 6 12-15-2008 02:45 PM
