Hanging A Beam Between Posts - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-06-2013, 01:26 PM   #16
Rewards Points: 528
as to one question asked earlier, 3.5" nails nailed opposite each other on he hangers, all you need is a slight angle and they wont hit each other.
As to the est, I really do not understand what you are attempting to accomplish.
framer52 is offline   Reply With Quote
Old 04-06-2013, 01:36 PM   #17
Rewards Points: 2,652
One thing you might want to check out.... if you start modifying the structure of that house, will you need to bring it up to current California code requirements?
SPS-1 is offline   Reply With Quote
Old 04-06-2013, 02:16 PM   #18
GBrackins's Avatar
Rewards Points: 2,108
I cannot speak for your area or building department, but in my area construction such as this would require a building permit, and structural elements such as proposed would need to be designed by a professional engineer. Post & beam type construction is not prescriptive construction in the 2009 International Residential Code, which I do believe is the basis of the residential building code in Cali. http://publicecodes.cyberregs.com/st...010-000008.htm
structural design is best left to knowledgeable and qualified individuals that can evaluate for themselves on-site the existing conditions and the construction you propose. An internet forum is certainly the last place I would attempt to seek structural design guidance since I do not know the people, their experience and knowledge or qualifications.
what you propose may or may not work depending on how loads are transferred through you home. it would be best to have a professional engineer prepare drawings and specifications that would demonstrate compliance with your building code and generally accepted engineering practices.
I am having a hard time like hand drive said wrapping my brain around a 19' long 4x4 that is supporting structural loads since I cannot view for myself the actual construction and the vertical distance between lateral supports. I would say that installing beams as your propose would reduce the unsupported vertical distance and may reduce the chances of buckling, however I do not know the species of wood and what affect these additional loads would have on the column and whether the column can support these compressive forces, or what requirements your code has for lateral loads.
Best advise I can give is hire a professional engineer. Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 04-06-2013, 03:14 PM   #19
Bill Kearney
Rewards Points: 1,174
I'd absolutely get a local engineer to explain what's going on there. When notions like "ran out of money" come into the equation I'd be VERY cautious about going forward without real engineering being considered. At the very least, see if you can get the original plans that were filed when it was built.
That and a few more pictures of the whole space would probably help. I can't quite grasp just where that space is and how it being that size makes any sense, to say nothing of the posts. Was this some sort of split-level style house or something?
wkearney99 is offline   Reply With Quote
Tags
beam , framing , post
Hanging a chandelier on a 3.5" wide wood beam diyjames2786 Electrical 2 07-24-2012 07:07 AM
Sagging Ceiling Joists - Adding Beam In Attic DoItMyselfToo Building & Construction 11 11-30-2010 06:20 PM
Deck Beam Crowned Not Hitting Middle Posts Dabber0069 Carpentry 7 08-24-2010 08:43 PM
replacing beam in basement bpahwa Building & Construction 4 01-12-2009 07:12 PM
How to replace wood support posts under main beam webjanet Building & Construction 1 09-07-2008 10:15 PM
