Hanging An Aluminum Awning - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-26-2013, 02:35 PM   #1
Lord of Slums
Rewards Points: 1,974
Hanging an aluminum awning
I should say re hanging an awning. The present awning is 4 foot wide 3 foot out from the front door. It has the side wings for support. It is lagged on with 3 inch lag bolts. So here is where things get strange, I can not grab a stud for the life of me. The awning is sitting about 14 inches above the top of the door, so it is above the door header. I tried everything and can not find a stud. The house is an old inner city Detroit house. It is aluminum siding over this clay like siding over lapboard sheeting. Then lath and plaster on the inside wall. Will a stud sensor find a stud? I am familiar with house framing just can not find a stud and do not understand what the deal is?
mj12 is offline   Reply With Quote
Old 02-26-2013, 04:14 PM   #2
It will inside and then you can transfer the stud location to the out side.
Hardway is offline   Reply With Quote
Old 02-26-2013, 04:20 PM   #3
Rewards Points: 192
Perhaps use a drywall toggle bolt with washers if you can't find the stud?
Larryh86GT is online now   Reply With Quote
aluminum awning crescere Building & Construction 1 01-02-2013 11:07 AM
Hot Water Anode: Aluminum vs Magnesium zootjeff Plumbing 4 12-14-2012 04:41 PM
hanging an awning martin 1 Building & Construction 2 05-08-2007 08:59 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
