Hang A Mirror By Crown Molding / Trim? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-22-2010, 02:02 PM   #1
Hang a mirror by crown molding / trim?
I have two 3' by 3' mirrors in my main bathroom which were originally held up by some kind of heavy duty mirror hangers behind the glass. I've taken them down to repaint our bathroom, and ended up recycling the old metal hangers. Now I need to put the mirrors back up.
I'm trying to avoid having to go buy more mirror hangers, plus the "floating" look isn't what we are after this time. So here is my idea: I will take some crown molding and attach it to the wall with a 1/4" slot around the inside edges, thus making a lip for the mirror to sit inside. Then I'd slide in the mirror and nail up the last piece on the sides. Thus the mirrors would be supported by the molding nailed into studs.
Will this work? Is there some kind of danger of the woodwork falling away - am I supposed to hang the mirrors first, then put the trim around them?
kennedy.greg is offline   Reply With Quote
Old 03-22-2010, 05:46 PM   #2
Drywall contractor
Rewards Points: 1,070
Find some sort of trim that already has a rabbetted edge on it like a chair rail that sits on top of wainscot paneling (for convenience). Place the bottom piece and fasten securely to the studs. Set the mirror in place (with a good "squirt" or two of mirror adhesive behind it. Install the side trim pieces with some liquid nails (or similar) and angle some brad nails into the drywall to hold until the glue sets. Add the top piece of trim and fasten into the studs.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
drtbk4ever (03-22-2010)
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 06:20 PM
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 01:33 PM
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 08:18 PM
Need help on Crown Molding on inset Trey Ceiling pacumming Carpentry 2 01-30-2010 01:13 AM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
