Hang Bottom Of Stair Stringers Below Floor With Joist Hangars? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-24-2013, 09:21 PM   #16
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,278
Originally Posted by Willie T View Post
A hanger board? I thought he was wanting to somehow anchor the BOTTOM, not the TOP.
Hanger boards are at the top, are they not?
I thought so also.... but it is the same idea the OP wnats to do on the bottom... I think.
MTN REMODEL LLC is offline   Reply With Quote
Old 06-25-2013, 06:47 AM   #17
Old School
Willie T's Avatar
Except that instead of pushing against a braced board, you would be pulling away from an un-braced board.
Willie T
Old 06-25-2013, 06:56 AM   #18
Keith... Could you explain that assembly?? How it's differnet than OP is proposing.
TIA
Yes Willie.... Maybe Keith will come back and explain the assembly.
Old 06-25-2013, 08:53 PM   #19
recently retired
Rewards Points: 280
I was able to resize the pic enough that I now think I know what is being asked.
As Willie said, NO you cannot use joist hangers for the first riser connection. The forces are NOT straight down, they are pulling the stringer away from the landing.
The hanger board is indeed for the top riser connection. However if goal is to increase headroom on the underside of the stair for the flight below you should consider a housed stringer stair. You could move the underside of the stair up at least 4".
Keith Mathewson is offline   Reply With Quote
The Following User Says Thank You to Keith Mathewson For This Useful Post:
nuclearnerd (06-29-2013)
Old 06-26-2013, 05:14 AM   #20
kwikfishron's Avatar
Rewards Points: 760
I'd be looking for a way to extend that floor so the stringer has something to sit on.
kwikfishron is online now   Reply With Quote
Tags
joist hanger , stairs
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 01:30 PM
Hang wall from floor joist HooKooDooKu Building & Construction 3 01-04-2010 08:50 AM
Cutting stair stringers for OLD basement steps 4just1don Building & Construction 1 08-11-2009 06:21 AM
Laying Out Stair Stringers FISH96 Carpentry 4 06-12-2008 11:26 AM
