Hang Bottom Of Stair Stringers Below Floor With Joist Hangars? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-23-2013, 11:02 PM   #1
Hang bottom of stair stringers below floor with joist hangars?
I'm trying to maximize the headroom under a new flight of stairs (above an existing flight of stairs) in a remodel of an old house. Usually you would set the entire bottom of the first step on the subfloor like this:
But doing so makes the ceiling of the stairway below drop suddenly where the stringers meet the floor joists. I'm wondering if, instead, I could support the stringers from the side of the floor joist using a joist hanger. That would give me more headroom, and would look something like this:
(Only with joist hangers off to the right of the floor joists, instead of the notches shown). Has anyone framed stairs this way?
nuclearnerd is offline   Reply With Quote
Old 06-23-2013, 11:11 PM   #2
Here's another view of what I'm thinking of. I haven't found many other examples online:
http://www.pic.stairs4u.com/splitlev...r_stringer.htm
http://www.pic.stairs4u.com/splitlev...to_landing.htm
Old 06-23-2013, 11:30 PM   #3
Old School
Willie T's Avatar
Frankly? Totally stupid. This "method" (if you want to call it that) offers almost NO support in the direction the forces will be exerting themselves.
Willie T
Old 06-23-2013, 11:42 PM   #4
Really? The forces are primarily down. Joist hangers can take care of that I would think. I'm more worried about the joist with hangers twisting due to the off-center load, but with a solid joist hanger, the stringers themselves will help that.
Unfortunately I have to come up with a way to increase headroom. The old stairs were grandfathered, but now that I've started renos (started with some minor work on the stair landing), my inspector is demanding that the headroom be increased to meet code (6'6").
Old 06-23-2013, 11:59 PM   #5
Old School
Willie T's Avatar
No, the forces are not just down. They are pivoted at the upper stringer attachment, and swing forward, toward that 8' hole... pulling away from those hangers, and progressively drawing the hanger nails slowly out of the lower platform side.
Willie T
Old 06-24-2013, 12:08 AM   #6
Old School
Willie T's Avatar
About the only way is to cut more out of the top floor, and shift the entire stairs forward.
Willie T
Old 06-24-2013, 12:15 AM   #7
I see where you're coming from Willie. But if there were no gap between the hanger and the bottom of the stringer, then there would be no room to rotate before the hanger pulls upward and stops the rotation. Think of it this way. For the bottom of the stringer to rotate outwards (once it is seated on the hanger), The stair opening would have to increase by 1.5" (seems unlikely), or the top of the stringer would have to push upwards. That's not going to happen when the load is pushing down.
In fact, if the upper hanger were slightly loose, there would be a force *into* the lower joist, as the stringer tried to rotate about the bottom hanger. This is why you have to install a "kicker" when setting the stringer on top of the sub floor.
Old 06-24-2013, 12:17 AM   #8
There's another floor joist above the upper stairs. If I shift the stairs forward to get headroom below, I loose too much above
Old 06-24-2013, 12:19 AM   #9
Another option could be to hang the stringer off the stud walls beside (with lag bolts maybe), but I'm even less comfortable about that idea.
Old 06-24-2013, 07:33 AM   #10
Old School
Willie T's Avatar
Like the man says, "You'll be walking on it, not me."
Willie T
Old 06-24-2013, 09:35 PM   #11
recently retired
Rewards Points: 280
I can't really see because there is a "bleep bleep bleeping" ad for Home Depot right in the middle of the pic but it sounds like you need a hanger board.
Keith Mathewson is offline   Reply With Quote
The Following User Says Thank You to Keith Mathewson For This Useful Post:
MTN REMODEL LLC (06-24-2013)
Old 06-24-2013, 10:00 PM   #12
recently retired
Rewards Points: 280
Your inspector is wrong, as long as you are not reconfiguring the dimensions of the stair-hole the older standards are applied.
nuclearnerd (06-24-2013)
Old 06-24-2013, 10:06 PM   #13
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,362
Keith... Could you explain that assembly?? How it's differnet than OP is proposing.
TIA
MTN REMODEL LLC is offline   Reply With Quote
Old 06-24-2013, 10:12 PM   #14
Old School
Willie T's Avatar
A hanger board? I thought he was wanting to somehow anchor the BOTTOM, not the TOP.
Hanger boards are at the top, are they not?
Willie T
Old 06-24-2013, 10:16 PM   #15
Old School
Willie T's Avatar
As far as whether the inspector is right or wrong....... well that depends upon the years of repeated hassle you want to set yourself up for.
You can win today's battle, (maybe), but the wounds you will suffer, (repeatedly), for years, is hardly worth it.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
Tags
joist hanger , stairs
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 09:00 AM
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 02:30 PM
Hang wall from floor joist HooKooDooKu Building & Construction 3 01-04-2010 09:50 AM
Cutting stair stringers for OLD basement steps 4just1don Building & Construction 1 08-11-2009 07:21 AM
Laying Out Stair Stringers FISH96 Carpentry 4 06-12-2008 12:26 PM
