Handrail Questions - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-09-2011, 11:49 PM   #1
Handrail questions
I'm going to attach handrails to my walls and I have a few questions before I start. I have brackets with three screw holes.
I'm assuming my studs are softwood? The reason I am asking is that all the references I see on pilot holes sizes differentiate between softwood or hardwood. I have also seen some different recommendations on pilot hole size. Most say that for softwood a #10 screw needs a 7/64" pilot hole. The one recommendation for a smaller hole (3/32") comes from the American Wood Council (AWC). I'm inclined to go with 7/64" as I'd rather not risk any chance of splitting the wood and it may make the screwing a bit easier.
The code for attachment of handrails says:
1) Handrails shall be attached to wood studs, wood blocking, steel studs or masonry at points spaced not more than 1.2 m apart.
2) Attachment to wood studs and blocking required in Sentence (1) shall consist of not less than 2 wood screws at each point, penetrating not less than 32 mm into solid wood.
32 mm is 1.25". The screws that came with my bracket are 1.25" exactly but I have to go through 0.5" drywall as well, so actually I'll be going through 0.75" of wood instead of 1.25" as the code says. The problem is that the screws are satin nickel oval head and I don't think I'll be able to find any of those in 1.75" or 2" anywhere. Any ideas? Should I go ahead and use those screws or should I look for some matching screws that are longer.
djgrant is offline   Reply With Quote
Old 06-10-2011, 07:40 AM   #2
2" screws are better. Drill size should be the same of slightly smaller than the shank of the screw. For wood screws, I measure the shank about 1/2 way up the screw. I usually angle the top two screws to get three screws into the stud.
Old 06-10-2011, 09:14 AM   #3
Rewards Points: 5,336
Originally Posted by athena3 View Post
If you continue with unmatched screws it would make the wood get damaged
I don't get this statement.
Ron
B. Franklin 1759
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 03:37 PM
Basic (hopefully) electrical questions k2000lbs Electrical 10 04-27-2011 01:59 PM
Handrail building code questions - Canada Peterpantz Carpentry 7 10-26-2008 01:24 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
Handrail questions. wfischer Building & Construction 2 03-24-2008 10:47 PM
