Which Handle To Use For Cutting Board? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-03-2014, 09:27 PM   #1
Which handle to use for cutting board?
I'm building a hard maple cutting board for my wife. It's almost complete. I realized it will be heavy and need to provide an easy means to pick it up. saw tons of handles at Leevalley Tools but looks like those are for cabinets. Is there a handle that I can install on side of cutting board?
thanks.
mechth is offline   Reply With Quote
Old 02-03-2014, 10:08 PM   #2
Professional
TotalHomeworx's Avatar
Can you post a picture?
www.totalhomeworx.ca
TotalHomeworx is offline   Reply With Quote
Old 02-03-2014, 10:30 PM   #3
here you go. thickness is 1.5"
http://tinypic.com/m/i2n2gm/4
Old 02-04-2014, 05:31 AM   #4
Rewards Points: 12,856
I'd make one like this out of maple and attach it to one end.
Just going to have to counter bore and drill two holes for the screws and plug them.
http://www.myknobs.com/ribp05411151.html
gregzoll (02-04-2014)
Old 02-04-2014, 08:35 AM   #5
joed's Avatar
Rewards Points: 11,588
Keep it simple cut two one inch holes joined and rounded over with a router.
The Following 3 Users Say Thank You to joed For This Useful Post:
BigJim (02-04-2014), gregzoll (02-04-2014), Startingover (02-05-2014)
Old 02-04-2014, 09:09 AM   #6
kwikfishron's Avatar
Rewards Points: 90
On the thicker/heaver boards I've done I like to cut in a handle with a router similar to this.
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
BigJim (02-05-2014), gregzoll (02-04-2014)
Old 02-04-2014, 09:25 AM   #7
Rewards Points: 6,652
Any handle you put on it, should not be on the face, but on the sides. I like the legs to allow you to get under it, to pick it up. Especially when after you oil them, they tend to get a little slick.
We used to make them in shop class all of the time. The ones we did, were no wider then 1". Always just a slab, unless someone wanted a handle, then we would just cut one in like in post#5, so that you did not have a surface for food particulate, to get into.
Old 02-04-2014, 09:35 AM   #8
Rewards Points: 438
Yes Sir !!!
As heavy as that board looks, cut a finger groove on all four sides at least 3 to 4 inches long with a cove bit or your best method. She'll need both hands to pick it up.
Beautiful board Kwik.
Old 02-04-2014, 09:49 AM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
My wife wanted a cutting board to fit one side of the sink with a hole to rake scraps into the sink, works great and easy to carry by the large hole in the corner. It also has a groove routed all the way around so juices won't run off the board and will drain into the hole and in the sink.
Be sure to ease the edges a little they can be very sharp.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 02-04-2014, 08:59 PM   #10
I'm confused on how to plug the screws in. unlike a cabinet door, there is no access from the other side. I'm thinking using the handle like this:
http://www.leevalley.com/US/hardware...20,43521,43532
Old 02-05-2014, 04:23 PM   #11
Professional
Looks like your best option to me
Old 02-05-2014, 05:23 PM   #12
Rewards Points: 2,038
I like my Boos cutting board which has groves in each end. Not sure if they're visible in this photo
Startingover is offline   Reply With Quote
Old 02-05-2014, 08:57 PM   #13
just curious does someone know how the handle in the link was installed? I saw similar products in some stores but couldn't figure out how they did it.
http://www.colourbox.com/image/cutti...-image-4273321
Old 02-05-2014, 11:08 PM   #14
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
The only two ways I can think of is like attaching the fitting on a stair rail or screw in studs which the handle slides onto with a lock screw in each side. Just my thoughts.
Jim
Old 02-07-2014, 10:20 AM   #15
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
I would go with a routed or cut handle. Keep in mind anything attached will tend to collect germs and make it more difficult to clean.
The Following 2 Users Say Thank You to Blondesense For This Useful Post:
BigJim (02-07-2014), Startingover (02-12-2014)
Lennox Furnace with 63K8901 circuit board behaving strangely tgice HVAC 4 06-21-2013 02:03 PM
Deck ledger board attachment higher than rim board Davenger Building & Construction 0 06-20-2013 11:30 PM
Foam board over old 4in thick fiber board roofing panels Rebob40 Roofing/Siding 2 03-05-2012 10:24 AM
Fascia board install - unlevel rafter tails giperbolic Roofing/Siding 3 01-18-2012 12:46 AM
shower rebuild - need help with backer board & green board johndoe12345 Tiling, ceramics, marble 2 11-27-2011 02:16 PM
