Hand Rails - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-01-2013, 08:31 PM   #1
hand rails
how can i lenghten a wood hand rail and make it strong and safe for a retirement home?
jerry kruetzkam is offline   Reply With Quote
Old 01-01-2013, 10:02 PM   #2
Rewards Points: 13,266
Need a rail stretcher.
Come on where going to know a whole lot more and see some pictures.
What style rail, inside, outside, what's it made of?
Old 01-01-2013, 10:43 PM   #3
Rewards Points: 692
If you can find some of the same profile you can spline a section of any length in to make it as long as necessary. Otherwise you'll need to make your own, copying the shape you have and adding it.
Attached is an example how I repaired a broken rocker of a child's chair making the rocker longer. You can either cut a tenon on the end of the new length as in this chair repair or cut the original rail and add a floating spline on both ends of the new section.
Old 01-01-2013, 10:54 PM   #4
If it's a standard wood hand rail you use a rail bolt.
http://www.stairsupplies.com/eng/pro...9600_rail_bolt
Old 01-01-2013, 11:12 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 186
I believe Fairview's method would be stronger than a rail bolt.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
