Hand Rail/drywall Repair - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-18-2008, 07:40 AM   #1
I have a two story home with a wrought iron railing from the first floor to the second. It is installed through the drywall. After kids wear and tear the railing has pulled loose and the dry wall has broken away where the railing is attached. I was looking for some advice on the best way to repair the dry wall and re-attach and secure the railing. Your help and ideas would be appreciated. Thanks in advance for your help.
Burger is offline   Reply With Quote
Old 08-18-2008, 07:57 AM   #2
Registered User
Termite's Avatar
Very strange that it is installed through the drywall. Could you possibly post a picture so we can understand exactly what you're dealing with?
Old 08-18-2008, 08:03 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
was the rail attached to the drywall or some blocking behind. The reason I'm asking I have seen wrought iron rails secured to walls with toggle bolts. if there is no blocking, cut out a section of the drywall so you could install some type of 2x blocking from stud to stud. then install a new drywall blow out patch, spackle and paint. if there is blocking behind the wall then spackle the wall and drill the rail for the next 1 or 2 size's bigger in screw size. GOOD luck BOB
Old 08-18-2008, 09:34 PM   #4
I can get a picture in a few days. I will re-post when I get the picture. Thanks
Old 08-18-2008, 09:36 PM   #5
I need to pull the railing off and get a better view of whats behind it. I guess I should start there. Thanks. I will re-post when I have more info.
Old 08-19-2008, 06:04 AM   #6
buletbob's Avatar
Any good plumbing supply stores Or you could go to a Home depot. remove the handle and unscrew the stem and bring it with you. this way they can match it up. If your not sure about putting the thing back together, then take some pictures so you have an idea how it goes back together. GOOD LUCK.
Damaged electrical box - How to repair? theScud Electrical 17 06-24-2014 12:07 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
drywall ceiling hole repair billyg Drywall & Plaster 5 06-10-2008 04:19 PM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 09:18 AM
Edge of roof deteriorated, how to repair? (pics) diymonkey Roofing/Siding 3 06-23-2007 01:02 AM
