Had To Break Down A Door, How To Repair Splintered Wood Around Lock Area? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-08-2009, 12:53 PM   #16
If you're in a tight spot get the glue and a 4" X 8 " nailing plate like what is used to brace rafters. Hammer it into the side and get out the wood filler. Your glue joint will becaome the strongest area. These plates are like what is now used to reenforce the jamb around an new exterior door lock and deadbolt cutout area.
Chemist1961 is offline   Reply With Quote
Old 06-09-2009, 08:03 AM   #17
Rewards Points: 150
Is that broken on the hinge side?
It takes less time to do a thing right than it does to explain why you did it wrong.
-Henry Wadsworth Longfellow
beer_geek is offline   Reply With Quote
Old 06-09-2009, 08:42 AM   #18
Use finish nails & put it back together
Some wood glue & putty & paint & it will look OK
Then figure out how to unlock it without busting it down for next time.
All the doors that lock in our house can be unlocked with acsrewdriver or a dime. Our sons room does not lock...yet
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
