Had To Break Down A Door, How To Repair Splintered Wood Around Lock Area? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-02-2009, 08:39 PM   #1
had to break down a door, how to repair splintered wood around lock area?
I had to break down a door, and a long piece of the door frame around the lock area almost completely splintered off, as well as the part of the lock attached to the door came off (however, it seems to be reattachable--it was held in place by two screws, and I can fit the screws back into the holes in which they were. They are along the line where it started to splinter. When I try to push the piece of wood back into place, it juts out a little, probably due to errant splinters of wood in the area where it splintered off that are now sticking out and preventing it from lying flush. Should I sand this down? Would I then just glue the screws of the lock back into place, and what should I use to reattach the piece of wood? I snapped a picture of the piece of wood using my cell phone, sorry the quality is so bad.
I realize this all sounds a bit shady, but as you might be able to tell from the picture, this was just a door inside my house that I stupidly managed to lock from the inside.
mxyplizk is offline   Reply With Quote
Old 06-02-2009, 09:25 PM   #2
Custom Cabinet Maker
New prehung door.
skymaster is offline   Reply With Quote
Old 06-02-2009, 09:41 PM   #3
er...that's a bit out of my price range. What if I just sanded it down, glued the screws back in place, used wood glue to reattach the chunk of wood, and filled in the gaps with wood putty?
Old 06-02-2009, 09:54 PM   #4
How about just buying a new piece of jam and replace it..
gotboost is offline   Reply With Quote
Old 06-02-2009, 10:50 PM   #5
You can try to glue,patch etc. lotsa work. as far as replacing that jamb ya gotta take to door fram out to do it right at that point new door is easier
Old 06-02-2009, 11:01 PM   #6
Registered User
Rewards Points: 5,260
Sure, just glue it. It won't lock anyone out, and will look like someone tried to repair it, but didn't quite pull it off. It may not latch or even close right from the kick. Put more paint on it to hide the repair but it may stick or rub there. Be safe, G
Gary in WA is online now   Reply With Quote
Old 06-02-2009, 11:05 PM   #7
Rewards Points: 1,016
If the casing is separate from the frame, how about glue in the piece broken from the frame and replace the casing? Use a good wood glue and some clamps.
Old 06-03-2009, 12:23 AM   #8
Money
If it is a interrior door you are looking at $30.00-50.00 depending on size, brand, where you are at. Exterrior doors start at about $100.00 at hd or L. Look ok too.
texas115115 is offline   Reply With Quote
Old 06-03-2009, 09:21 AM   #9
Rewards Points: 5,336
There are many ways to open a locked interior door without breaking it down. Remove the hinge pins or unscrew the knobs and turn the latch .
This is for next time.
Ron
Old 06-03-2009, 02:15 PM   #10
Registered User
You made me think, Ron. The hinge pins and screws to the lock are usually on the same side (inside) as the lock. But even in the 70's when I first installed privacy locksets, they had the center hole in the knob for getting a child out having a bad day. And the current ones have a slotted button in the knob. It's a code thing. Hopefully the Op's has one. Be safe, G
Old 06-03-2009, 02:33 PM   #11
RippySkippy's Avatar
If you absolutely have to destroy something to get through a locked door...use a 1/4" drill and take the center out of the key way, letting the pins fall out. Replace the key way and pins an you're back in business. DAMHIKT...had to do it on my own house...once.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 06-03-2009, 04:09 PM   #12
You can usually find some thing to go into the hole. I've used a paperclip on occassion for the push ones or a 6d finish nail. Small electronic screw driver for the ones that turn.
It would have to be a real emergency for me to break open the door.
Ron
Old 06-03-2009, 04:44 PM   #13
Newbie Bill
Rewards Points: 520
It's all those darn cop shows that teach these things you know.
Personally, I have used those wooden BBQ skewers to rescue the daughter from the bathroom. Poked it in the little hole in the doorknob.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
Old 06-03-2009, 05:09 PM   #14
Rewards Points: 1,910
First sign up for Anger Management Classes. Cause accidentally locking the door wasn't what you did stupidly - it was the way you unlocked it.
I suppose you could try to clean up the splintered edges enough to glue it back together but it's going to be very weak and probably not look good unless you're very patient - and I think we've pretty much figured out how patient you are.
Old 06-03-2009, 07:29 PM   #15
Household Handyman
Rewards Points: 1,408
The picture is not all that good but it looks like you busted out the jamb and trim on that one side. You can buy a new jamb and trim to replace the busted ones and fit them in.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
