Grouted Backsplash - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 01:11 PM   #1
Grouted Backsplash
I want to replace my laminate counter tops with Corian but the tile backsplash is grouted to it. Do not want to remove and replace tile because of cost. What would you suggest I do to seperate the two? I have a 4" angle grinder and you can get masonary wheels for it, how about doing that?
rlegrow is offline   Reply With Quote
Old 03-07-2011, 01:49 PM   #2
Rewards Points: 5,330
Grouted Backsplash
Remove the sink.
Cut the counter as close to the backsplash as possible.
Make sure the counter is unscrewed from the cabinet.
Gently pull the counter piece towards you(it might just slide out)
If not, remove enough grout to free up the counter piece.
Ron
Old 03-07-2011, 02:07 PM   #3
mem
Rewards Points: 154
Grouted Backsplash
Seems like an angle grinder may be a little tough to control, especially in a tight space like a grout line. Could easily damage the tiles you are trying to preserve, not to mention the debris it will throw everywhere. A grout saw would be safer, if that's your main concern. If you're lucky enough to have a MultiMaster type saw, use that.
mem is offline   Reply With Quote
tiling over laminate/formica backsplash doqfleed Tiling, ceramics, marble 4 06-15-2010 12:25 AM
Tiling / backsplash question Mark755 Kitchen & Bath Remodeling 4 02-26-2010 02:01 PM
backsplash... change of plans juliebun Kitchen & Bath Remodeling 2 06-07-2009 05:27 PM
Can I put up a glass-block backsplash over a laminate? coreyjan Tiling, ceramics, marble 1 05-24-2009 08:47 AM
Attaching a backsplash to wall/countertop DanBress Carpentry 3 09-10-2008 09:09 PM
