Granite Countertop Install Procedures? - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-20-2009, 07:27 AM   #1
Pursuit of Perfection
Granite countertop install procedures?
Hello Folks,
I am in the final stages of our full kitchen remodel and decided to sub the countertop installation to "professionals". We chose 2cm thick granite and after researching the procedure, the contractor was contacted that I was ready for him. I prepped the cabinets for his arrival by paying a lot of attention to levelness and extra cleats near the dishwasher that I knew he would need. When he arrived for measurements, he made no template whatsoever. I asked why and he said if the walls ran off any, they would just cut the wall out to make it fit. Installation day comes, they arrive with 3/4" OSB strips to screw to the top of cabinets! I inquired about full plywood base as thats what I thought they would use. It seemed to ruffle their feathers, but they left to go get plywood. Their poor attempt at cutting the plywood proved to me they may not be "professionals". To make a long story short, what is standard procedure for installing 2cm granite? Full plywood base? Are there usually any wood cleats/strips that actually hold undermount sink in or just epoxy? The template for sink cutout isnt even close (i.e. poor radiuses, not straight lines parallel to each other). What would you do at this point? I am hoping for some installers opinions/comments. All your input is greatly appreciated!
DIYmakeover is offline   Reply With Quote
Old 04-20-2009, 10:20 AM   #2
Rewards Points: 5,336
If the job sucks, tell them to fix it or remove it.
When my granite counters came, the bump out for the sink was off by 4" and the "S" curves were two different shapes. They took it back to the shop and fixed it that day.
Ron
Old 04-21-2009, 10:44 AM   #3
Anyone had any experience either installing or watching their own granite being installed that can help me???
Old 04-22-2009, 01:07 AM   #4
Rewards Points: 1,016
I had a outfit install prefabricated granite countertops for me.
My granite was 2cm. With 2cm granite, there should be full plywood everywhere to provide strength and support. If 3cm granite it would be installed directly to the top of the cabinets.
They made no templates - but did do a zillion measurements every which way and drew a cutting and placement plan. There were some variences along the walls - maybe 1/8" - 1/4" at the maximum, but nothing that the backsplash would not readily cover and hide the gap. I had the same 2cm granite installed 6" high as the backsplash.
I have a stainless undermount sink. The sink lip is sandwiched between the plywood and the granite, with silicone applied as waterseal and adhesvie. The cutout in the plywood was done very neatly following the contour and shape of the sink. It looks very neat - both above where it really counts, and underneath as well.
They had four guys here all day - fitting, grinding, lifting, etc. I was surprized at the amount of time spent and onsite fabrication they did. Made me glad of my desician to not do it myself.
Pictures attached of the finished job.
Granite countertop install procedures?-dscn0702.jpg   Granite countertop install procedures?-dscn0703.jpg   Granite countertop install procedures?-dscn0704.jpg   Granite countertop install procedures?-dscn0705.jpg   Granite countertop install procedures?-dscn0706.jpg
Old 04-22-2009, 07:23 AM   #5
Thanks for the input! I have done extensive reading on how 2cm granite seems to be installed. These guys didn't use full plywood bases and there is nothing holding the undermount sink in except some epoxy on the four corners. I watched them attempt to cut plywood and it looked like they used an axe! I initially had a thought of paying them for the granite itself, having them leave it in the yard and installing myself. After discussing it with my wife, we decided to let them do it. They were done in less than 2 hours and the workmanship is terrible! The cutout for the sink looks like the guessed at the sink size instead of using the template I gave them. I will see what their next move is to make it right. My real problem is I have to wait for who knows how long before I can hook up sink and water, which we have been without for 2 months during the remodel. I appreciate all others input!
Rick.
Old 04-22-2009, 11:26 AM   #6
Registered User
Termite's Avatar
You know what's wrong, so why not call a representative from their company and request that they meet you at your home to give them your thoughts on the low level of craftsmanship. They sound like hacks to me, and hopefully you haven't paid for the job yet.
Old 04-22-2009, 12:40 PM   #7
Kitchen remodel Guru
A.W. Davis's Avatar
2cm granite requires a subtop with 5/8" plywood underneath the granite. The granite is then adhered to the plywood by construction adhesive.
Sounds to me like this granite contractor is probably doing a sunstandard installation. 3/4" strips is completely unacceptable!
A.W. Davis is offline   Reply With Quote
Old 04-22-2009, 03:31 PM   #8
I have stopped payment on the 2nd half of the job....luckily! They have promised me for two days to come out to try to make me happy....always something comes up and they can't get here! I'm angry with myself that I let them continue after I noticed the 3/4" strips and not full sheets of a base. The backsplash has a bullnose to the top and where it meets in the corners its just packed with clear silicone. I feel it should be mitered/coped to fit better. We had hopes of this granite being the center-piece of the kitchen but it has turned out to be the nightmare instead. Thank you to all that responded thus far....I built laminate countertops for 10 yrs with my Dad who was a successful self-employed contractor for over 40 years. I'm not claiming to know everything but I knew this installation was not right but I wanted to ask about current installation procedures here!
Rick.
Old 04-22-2009, 04:55 PM   #9
Carpenter
Sorry for your bad luck and the hacks you ran into. This is getting to be all to common. I hope you get the situation resolved to your liking without too much problems.
Bucky Badger is offline   Reply With Quote
Old 02-07-2011, 07:31 PM   #10
DIYmakeover,
It looks like you live in the Pittsburgh, PA area? Where did you find prefabricated granite countertops? I know Mont granite sells slabs, but I'm interested in the prefab. Thanks for any help you can give me.
spatn1212 is offline   Reply With Quote
Old 02-07-2011, 09:07 PM   #11
Rewards Points: 290
Old tread I know, but if the OP does respond, I am curious as to why he has what looks like two spaces for refrigerators. Is one actually a freezer?
Jim F is offline   Reply With Quote
Old 02-08-2011, 02:34 AM   #12
@ Jim F-- looks like one hole for a fridge, and one for a stove (the one with the tall backsplash..)
1910NE is offline   Reply With Quote
The Following User Says Thank You to 1910NE For This Useful Post:
Jim F (02-08-2011)
Old 02-08-2011, 09:15 PM   #13
Granite laser measurement
"he made no template whatsoever. I asked why and he said if the walls ran off any, they would just cut the wall out to make it fit".
I'm sorry you didnt throw the bum out after he said that statement above.
I had a brand new kitchen completed just last year and the Granite guy set up a laser device in the middle of my kitchen on top of a tripod. The guy tapped different corners in my kitchen for the device to read and then a complete scan was recorded. They used the recorded results to cut the stone. It's scary how perfect the measurements came out.
Let us know how things end up.
zman22 is offline   Reply With Quote
Old 02-09-2011, 07:57 AM   #14
Ok here, homeowner what did you pay for as stated in contract? I am a fabricator. there are a plethera of ways to install 2cm granite. IDEALLY, a 3/4 marine plywood is the best substrate to use under 2cm granite. However, to my customers on budgets, I simply explain to them they will have 3/4 strips of plywood laminated to back of granite on the edges that wont be visible. I laminate across the length (23") of the granite as well with 3/4 strips. Another option is to laminate strips of the same thickness material or matching material to the bottom of granite on edges that wont be visible as well as the length again. in my training at different shops everyone did things differently. they should have communicated to you what you were getting.
acglobal is offline   Reply With Quote
Underlayment for Granite Countertop JESTERJD Remodeling 9 08-23-2009 01:02 PM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 11:44 AM
granite tile countertop installation had Building & Construction 3 04-01-2009 05:30 AM
install sink in granite after basic install? damstenger Remodeling 3 02-06-2009 06:37 PM
