Grandma Wants A Handrail. - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-30-2008, 02:12 AM   #1
wfischer's Avatar
Grandma wants a handrail.
So, while working on the never-ending list of home improvements at grandma's house today, she asked me if I could install a handrail down to her basement. The stairs down to the basement make 2 right turns, to make a squared-off U shape. My first thought was to have a single "continuous" handrail, and just miter the corners... but then I realized it would be a compound angle and I got intimidated by the math. My next thought was to do 3 separate sections and just leave it at that... but then I read a post that said code requires all handrails to have returns. So now I'm wondering, would it look better to have 3 sections, for a total of 6 returns, or a continuous rail with returns just at the top and the bottom?
If I go with the continuous rail, how do I figure out the angles? Cutting them isn't a problem, I have a compound mitre saw.
And while we're on the subject, how far apart should the brackets be?
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape!
wfischer is offline   Reply With Quote
Old 03-30-2008, 08:48 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Continuous rail, with returns on the two ends.
How many rail brackets depends on the length. Generally brackets are installed according to the railing span.
- Build Well -
Old 03-30-2008, 09:55 AM   #3
wfischer's Avatar
How would a humble simpleton such as myself figure out exactly how to set the miter saw to cut these angles?
Agreed. The 3 walls are 30", 67", and 41". I'm guessing 2 brackets on each of the shorter rails, and 3 or 4 on the 67"?
And as for connecting all these pieces together, am I safe to assume the dowel-and-glue method would suffice?
Old 03-31-2008, 10:00 AM   #4
wfischer's Avatar
Help me Obi-Wan Atlantic, you're my only hope.
So last night I went and measured 36" up from the nose of the top step and the nose of the step at the first corner. Made marks, snapped a chalk line. Repeated for the other 2 lengths of stair. What I discovered at the corners did not make me happy at all, so I snapped some photos of it.
The magenta arrows link the chalk line to the step it was measured from.
So am I out of luck for a continuous handrail? Or did I just measure wrong?
Grandma wants a handrail.-arrows.jpg   Grandma wants a handrail.-im000067.jpg   Grandma wants a handrail.-im000069.jpg
Old 03-31-2008, 12:48 PM   #5
Rewards Points: 1,910
Wouldn't it be better to put the handrail on the outside of the turn so grandma doesn't have to step on the little wedge of the step at the turn? I'm sure she'd be steadier stepping onto a >10" wide step rather than a 3" wide step. If you did it that way I think your heights would match better.
Old 03-31-2008, 02:45 PM   #6
A.) When you are going around those corners, you "may" have to adjust the railings. Note the direct drop-down (goose-neck-connections) of the railings at certain transition locations in the pics posted below (from this site: http://www.stairworld.com/)
B.) When attaching railings together, in the inndustry, we use rail bolts. You could probably get by with dowels and glue, in your situation.
The number of brackets that you mentioned, appear sufficient. Tho, 3 brackets should suffice for the 67" length.
Examples of A: Notice railing drop downs (goose-neck) at corners
http://www.stairworld.com/180.html
http://www.stairworld.com/curveB.html
http://www.stairworld.com/holidaywood.html
http://www.stairworld.com/curveC.html
Examples of pre-formed goose-neck railing sections:
http://www.stairsupplies.com/eng/products/fittings
Example of B: Rail Bolts
http://www.stairsupplies.com/eng/pro...9600_rail_bolt
Over-all, I don't believe that you need to do such detailed craftsmanship in that stairwell. You may opt to consider just doing multiple railing segments with returns.
Good Luck.
- Build Well -
Old 03-31-2008, 04:22 PM   #7
wfischer's Avatar
I came to the same conclusion about the heights matching, but unfortunately putting the handrails on the outside of the turn isn't an option. There's a cubbyhole in the wall next to the top wedge-shaped step (not shown in the photos) that would be blocked by the rail.
Old 03-31-2008, 04:28 PM   #8
wfischer's Avatar
Another idea I thought of was to maybe put in some wood screws, countersink them, and cover the hole with putty.
Yeah, I wanted it to look fancy... but the more I look into it, the more problems pop up, and I think doing 3 segments is probably just the easiest way to go.
As always, thanks for the wealth of information. This site wouldn't be the same without people like you. I'm sure I speak for a lot of people when I say that I appreciate the time you take out of your day to help us out here.
Old 04-05-2008, 01:10 PM   #9
Carpenter
The Stairguy's Avatar
I think th min space from the wall to the side of the rail is 1 1/2". Careful cutting!
The Stairguy is offline   Reply With Quote
Pig's Ear handrail woodyjohn Carpentry 9 11-28-2014 04:08 PM
handrail ends farrington135 Carpentry 12 05-23-2013 02:51 PM
Handrail questions. wfischer Building & Construction 2 03-24-2008 10:47 PM
Solo handrail for outside?? bujaly Carpentry 3 05-22-2007 12:55 PM
Installing a handrail handbanana Carpentry 14 03-29-2007 05:14 PM
