Grambrel Roof Question - Dimensions - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-08-2011, 01:13 AM   #1
Grambrel Roof Question - dimensions
I have what should be an easy question but am having trouble finding information, or when I do find an answer, it is not the same as I worked out.
I am building a grambrel shed, 10 feet wide. I am going with 22.5 degree angles and my calculations (based on 10 feet wide and five foot high starting points) are 45 and 3/4 inches (long side)for each of 4 pieces that will be cut at 22.5 degrees. I will be using wood gussets (9 x 16").
The figures I ge on the internet for 10 foot wide and 22.5 degrees are either 45 inches or 43 and 15/16 inches. I saw something that said multiply your length by .366 (that gives 43.92 inches).
I have layed my template out on the basement floor and now the deck of my new shed, and each time still get 45 and 3/4 inches.
Anyone know why the answer is so hard to find? I mean the problem is basically where does the mid point of a 1/4 of a circle that is a 5 foot arc lie. Each time I get the same thing.
North178 is offline   Reply With Quote
Old 08-08-2011, 08:59 AM   #2
Rewards Points: 190
Using pencil and paper I get 45.9" which pretty much confirms your 45.75". There is a lot of bum dope on the internet as well as a wealth of good information. Cut 45 and 3/4" slightly large.
zircon is offline   Reply With Quote
Old 08-08-2011, 10:09 AM   #3
Rewards Points: 252
I am also getting 45.9" on the exterior of the truss (aka long side)
shazapple is offline   Reply With Quote
Old 08-08-2011, 07:19 PM   #4
thx shazzaple and zircon
I'll go with 45 and, as they say, a big 3/4" ....lol
much appreciated.
Cold Deck flat roof and insulation question... paredown Roofing/Siding 16 05-15-2012 05:11 PM
Roof Vent Question jrref Roofing/Siding 3 04-10-2011 05:20 PM
Roof Rafter question Rookie3550 Building & Construction 3 07-29-2010 01:30 PM
Another roof ventilation question Jim F Roofing/Siding 9 05-13-2010 07:51 PM
roof leak question joshm Roofing/Siding 23 04-04-2008 10:44 PM
