Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-17-2011, 05:36 AM   #1
Good stud finder?
I purchased a stud finder at the local true value store for $16 and it is crap. It finds the left side of the stud (maybe) but not the right side. Basically useless. What is a good brand and model stud finder to use that isn't too expensive.? Is it wise to get one with Electrical detection?
I need this to hang some brackets for heavy shelves if you're curious.
eyedrinkvenom is offline   Reply With Quote
Old 08-17-2011, 07:32 AM   #2
Good stud finder?
Upper end models usually are fine in drywall and have electrical and/or metal scanning as well. They all tend to falter in plaster, on tile, etc. On drywall, there is always the tap-with-a-hammer stud finder, almost always works.
Old 08-17-2011, 07:39 AM   #3
Good stud finder?
Hi Bill. I tried tapping but couldn't tell well enough. Maybe because there's layers of paint over the drywall? I just renovated this room over the past 2 months and the last thing I want to do is destroy the walls.
By upper-end models you mean whatever is expensive? I think I saw a few that were between $30-$50 I thought maybe some were better than others.
thanks
Old 08-17-2011, 08:33 AM   #4
Good stud finder?
Simple, no batteries, for around the house works great for me. http://www.acehardware.com/product/i...ductId=4334281
josall is offline   Reply With Quote
Old 08-17-2011, 08:52 AM   #5
Good stud finder?
So how can you tell where the stud is? You just assume the existing nail it's detecting is centered?
Not sure if I trust that. My luck I'll find an electrical conduit or a water pipe.
Thanks for the info though. For this I want to go a bit more high tech to stay on the safe side.
Old 08-17-2011, 06:37 PM   #6
Moderator
kwikfishron's Avatar
Good stud finder?
There’s usually a stud just to the left of an electrical outlet, you can pull layout off of that.
Baseboard nailing can also be a clue.
I own a stud finder but can't remember the last time i used it.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 08-17-2011, 06:45 PM   #7
Good stud finder?
Unfortunately whoever installed these outlets decades ago wasn't too swift. They are upside down, even the light switches are. God only knows where they put the wires.
Old 08-18-2011, 09:53 AM   #8
Newly Retired
tuchodi's Avatar
Good stud finder?
I have the Zircon and it was about $30. It has a switch for reg, deep or electrical and it has worked great for about 5 years now. It even works on a ceiling that has stipple but is a little hard to be consistent on that surface.
tuchodi is offline   Reply With Quote
Old 08-22-2011, 10:03 PM   #9
Good stud finder?
I have a couple of small "rare earth" magnets and they have NO problem finding the nails or screws that go into the stud. Just hold them in your hand and they "jump" right to the screws. Never a false reading! To find exact center a few 5/32" drill holes and I'm right on...
Johnboy555 is offline   Reply With Quote
Old 08-23-2011, 06:45 PM   #10
Good stud finder?
Thanks guys. I ended up getting a zircon, I think it's an i65, was the best they had. Works great so far.
Old 08-23-2011, 07:13 PM   #11
Tileguy
Bud Cline's Avatar
Good stud finder?
The Kardashians seem to make pretty good stud finders. I don't think any of those big asses will fit in your tool box tho.
The Following User Says Thank You to Bud Cline For This Useful Post:
gregzoll (08-24-2011)
Old 08-23-2011, 08:02 PM   #12
Good stud finder?
Sorry, I need an intelligent stud finder
Old 08-23-2011, 08:06 PM   #13
Tileguy
Bud Cline's Avatar
Good stud finder?
Oh yow! Well then nevermind.
Old 08-24-2011, 09:17 AM   #14
Good stud finder?
There is no "upside down" for outlets (or outlet boxes). They can be installed either way. And if the switches are upside down, why not just unscrew them and turn them over?
I would not trust that there's always a stud to the left of an outlet. There most always is, probably because the electrician nailing up the boxes was right-handed, but it's not a certainty.
Old 08-24-2011, 10:08 AM   #15
Good stud finder?
I can't turn them over because they are mounted outside the wall with conduit. By upside down, I mean the ground is on top with the 2 other holes on the bottom.
At any rate, it will suffice for now. The stud finder I got has an AC detection and so far it has prevented me from electrocuting myself
Stud finder and lead based paint? thunderhead Electrical 1 07-24-2011 07:49 PM
Odd stud size and location? help? mbrown4844 Home Theater 9 03-01-2011 10:37 PM
Finding AC wires with Ryobi stud finder darsunt Tools 4 03-21-2007 08:43 PM
Best reasonable stud finder??? Sellncars Tools 6 10-03-2006 09:29 PM
Stud Finder problem... kalaniwavo Carpentry 4 02-26-2006 08:24 PM
