Going Through Double Stud Of Load Bearing Wall. - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-27-2010, 10:19 AM   #1
Question
Going through double stud of load bearing wall.
Hello All,
I looking for some assistance. I'm in the process of putting my 55 gallon fish tank in the wall between my kitchen and living room. We decided we wanted to hide the filter (Rena Filstar XP 3) in a cabinet in the kitchen. So I want to run (2) 7/8" O.D. lines through the double 2'X4', as well as the plug for the aquarium light and UV filter. Attached is a photo of what I'm looking to do. I'm thinking that it would be best to run conduit in the wall for future changes and possible leaks, but I'm stumped on how to support the double 2' X 4' when I need a minimun of 2" hole in it.
poptot
poptot is offline   Reply With Quote
Old 07-27-2010, 10:41 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Originally Posted by poptot View Post
Hello All,
poptot
Why do you need a 2" hole, drill 2 - 1" holes
Coastal South Carolina
Old 07-27-2010, 12:52 PM   #3
Handyman
Rewards Points: 512
Works for me
canadaclub is offline   Reply With Quote
Old 07-27-2010, 01:58 PM   #4
Registered User
Rewards Points: 5,514
If 2" is needed and you don't exceed the load ratings, scroll down on this site: http://www.strongtie.com/products/co...-SS.asp#tables
Be safe, Gary
Old 07-27-2010, 03:44 PM   #5
If I put one 2" hole, I can run both intake\return, Hood Light Plug Wire and UV Clarifier plug wire through it. If I put in two 1" holes, I still have no place to run the wire for the Hood Light and UV Clarifier.
Old 07-27-2010, 03:47 PM   #6
A "Handy Husband"
rjniles's Avatar
Put is 2 1" holes for the pipes, drill a smaller 3rd hole for the rest. Stagger them about 1 foot apart.
Old 07-31-2010, 09:24 PM   #7
Can't you add to the thickness of the wall to accommodate the two inch hole without sacrificing compressive strength?
mrgins is offline   Reply With Quote
Old 07-31-2010, 09:58 PM   #8
Tom Struble's Avatar
Rewards Points: 2,002
add more studs
Tom Struble is offline   Reply With Quote
Old 07-31-2010, 10:03 PM   #9
A "Handy Husband"
rjniles's Avatar
Run that header all the way to the stud on the far right. Then close in the box for the tank. then all your plumbing and wiring will be under the header.
Old 07-31-2010, 10:11 PM   #10
Mabc's Avatar
Drill your hole and then put a metal plate on each side of it.
Mabc is offline   Reply With Quote
Old 08-01-2010, 11:59 AM   #11
Thumbs up
All of the above will work
how to-create doorway in load bearing wall Nikkil Building & Construction 4 05-13-2011 11:31 PM
Load bearing wall removal options ikessky Remodeling 2 08-24-2009 03:18 PM
load bearing wall under king post trusses jimby Carpentry 5 01-02-2009 05:15 PM
load bearing wall no more grant Building & Construction 5 10-14-2007 08:50 PM
Load Bearing Wall rpatterson Building & Construction 2 10-29-2005 07:43 AM
