Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-12-2008, 11:16 AM   #1
gluing a veneer
I have a coffee table that has a veneer problem. Due to the lack of humidity where I live, a small section has separated & raised slightly. I think I can get some wood glue underneath. My question is, what can I use between the clamp and the veneer itself that doesn't stick? I'm thinking maybe parchment paper (the cooking kind, which is impregnated with silicone). Any thoughts on that or maybe something else? Thanks!
steve771 is offline   Reply With Quote
Old 11-12-2008, 11:24 AM   #2
the Musigician
DangerMouse's Avatar
gluing a veneer
i'd use some glue, push it to spread, wipe off excess with damp rag, then wax paper or parchment, then a block of soft wood, THEN the clamp(s). (you don't want the clamp to leave an imprint.)
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 11-12-2008, 07:51 PM   #3
gluing a veneer
Right, that was what I was looking to do. So you think the wood glue won't have an effect on the parchment paper then? Thanks.
Old 11-12-2008, 08:00 PM   #4
the Musigician
gluing a veneer
not sure about parchment, pretty sure wax paper will do though.....
DM
Old 11-15-2008, 02:10 PM   #5
Drywall contractor
gluing a veneer
I'd trust the wax paper........
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-15-2008, 04:02 PM   #6
BUILDER / REMODELING CONT
buletbob's Avatar
gluing a veneer
2nd the wax paper
Stone Veneer Weight kinglerch Building & Construction 2 08-28-2008 10:39 AM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 09:21 PM
Mounting Plasma TV on Brick Veneer Bob_Alias Remodeling 3 01-29-2007 07:14 AM
Mounting Plasma on Brick Veneer Bob_Alias General Discussion 1 01-03-2007 09:53 AM
