Gluing A Joint - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 04:05 PM   #1
analogmusicman's Avatar
Rewards Points: 560
gluing a joint
I'm making a frame for a mirror, I don't want to stain and poly after the frame is installed,therefore what I'd like to do is stain and poly everything before I clamp and glue the frame on the mirror. my question is whether or not the "titebond" will make a good solid bond between pieces of wood that have stain and poly on them.
tnx,
analogmusicman is offline   Reply With Quote
Old 12-13-2011, 04:44 PM   #2
just tape off the areas where the glue will be when you finish the frame so the glue can grab.
Old 12-13-2011, 05:41 PM   #3
In a little over my head
Rewards Points: 706
Wood glue might bond stained wood. I doubt you'll get much bond at all on poly'd wood. There may be some other types of glue you could use, tho. Maybe gorilla glue? Never tried it.
ratherbefishing is offline   Reply With Quote
Old 12-13-2011, 05:45 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Can you biscuit the corners first?
Old 12-13-2011, 06:37 PM   #5
Rewards Points: 560
that would be the way to go Bud if the joint was larger but since it's a pretty small frame it wouldn't be practical. anyway, I haven't got the right tools. I like the idea of just taping the areas to be glued.
tnx,
Old 12-14-2011, 03:35 PM   #6
Rewards Points: 706
Miter joints are tough.
This is a great idea:
Doweling kits are really inexpensive. It seems like the one I bought (before I got biscuit joiner) was about 10 bucks. It came with the center markers, a drill bit and dowels. Can't find that set now, but this is the idea:
http://www.mannyswoodworkersplace.com/6110080.html
http://www.rockler.com/product.cfm?page=859
Here's a lot nicer one:
http://www.homedepot.com/h_d1/N-5yc1...1&ddkey=Search
Not even sure how it works.
Old 12-14-2011, 05:01 PM   #7
Rewards Points: 5,336
tnx,
You don't stain and poly where the glue is going to go. If you did already, sand it off.
Along with the glue, you should nail the corners.
Ron
B. Franklin 1759
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
CBU Joint Issue? cobrakai Kitchen & Bath Remodeling 1 01-19-2011 10:11 PM
PVC Sprinkler Leak at T Joint D2D2 Landscaping & Lawn Care 3 08-26-2010 04:57 PM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 11:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
