Glue And Dowels Sufficient To Build Speaker Pedestal? - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-24-2012, 12:58 AM   #1
Rewards Points: 682
Glue and dowels sufficient to build speaker pedestal?
I am thinking about trying to build a speaker pedestal out of poplar wood. To avoid screws I am thinking about drilling holes for dowels (with the help of a wood template) and wood glue. I heard wood glue is really strong. Would this make a pedestal strong enough to securely hold a 40 pound speaker? The top and bottom pieces would be 2 X 18 and there would be two vertical pieces that would be 2 X 12. The local stores do not have 3 X 3 pieces for posts.
darsunt is offline   Reply With Quote
Old 04-24-2012, 06:29 AM   #2
the Musigician
DangerMouse's Avatar
Easily, yes.
DM
Old 04-24-2012, 09:07 AM   #3
CrossWorks's Avatar
Rewards Points: 150
I would do one of two thing personally. Either increase the size of your vertical supports from 2" to 3", or stay with the original size and add two more so that you have one at each corner.
I understand the appearance is what matters, but I think the initial approach is a bit weak. Granted I'm sure the stand will stay in one place and rarely be moved, but I think stability may be an issue.
A great personality will open many doors in life,
but it's your character that keeps them open!
www.crossworksme.com
"Where Every Nail Has a Purpose!"
CrossWorks is offline   Reply With Quote
Old 04-24-2012, 12:11 PM   #4
Rewards Points: 682
Thanks.
I'm having trouble finding strong post shaped poplar pieces from local hardware. Maybe the local lumberyard has some.
Old 04-24-2012, 02:35 PM   #5
CrossWorks's Avatar
Rewards Points: 150
How about looking for a business that works with moldings or wood turnings. We have a few around here so I'm sure you've got the same situation there. We have a local guy here named Stephen Hanson who I consulted once about putting together a stair railing in a historical district here in Portland, and I got to visit his shop. Very impressive to say the least.
But what I did notice [in his case] was that there ample sources of balusters & table legs every where from various jobs in the past. Kind of the leftovers which I'm sure served as good samples to view.
But the point is, find someone who does wood turning and I'm confident they'll have a few table legs kicking around to sell for cheap.
Good luck.
Old 04-24-2012, 05:51 PM   #6
Rewards Points: 150
I am 6'2 - 220 lbs and I can sit on a 18" sq. top table with four 2"x2" popular legs and will never worry about it breaking down. Vertical strength in wood is awesome, its the horizonal plane that makes it weaker. Make a 3" band around the legs under the top, to help on the side to side movement. ..
Lowes has a good assortment of popular pieces in their finished woob rack with the oaks, camber pine etc. good luck
Jeeps is offline   Reply With Quote
Old 05-04-2012, 03:32 PM   #7
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
My thoughts exactly
woody4249 is offline   Reply With Quote
