-   -   Glue and dowels sufficient to build speaker pedestal? (http://www.diychatroom.com/f14/glue-dowels-sufficient-build-speaker-pedestal-141284/)
darsunt 04-23-2012 11:58 PM
I am thinking about trying to build a speaker pedestal out of poplar wood. To avoid screws I am thinking about drilling holes for dowels (with the help of a wood template) and wood glue. I heard wood glue is really strong. Would this make a pedestal strong enough to securely hold a 40 pound speaker? The top and bottom pieces would be 2 X 18 and there would be two vertical pieces that would be 2 X 12. The local stores do not have 3 X 3 pieces for posts.
DangerMouse 04-24-2012 05:29 AM
Easily, yes.
DM
CrossWorks 04-24-2012 08:07 AM
I would do one of two thing personally. Either increase the size of your vertical supports from 2" to 3", or stay with the original size and add two more so that you have one at each corner.
I understand the appearance is what matters, but I think the initial approach is a bit weak. Granted I'm sure the stand will stay in one place and rarely be moved, but I think stability may be an issue.
darsunt 04-24-2012 11:11 AM
Thanks.
I'm having trouble finding strong post shaped poplar pieces from local hardware. Maybe the local lumberyard has some.
CrossWorks 04-24-2012 01:35 PM
How about looking for a business that works with moldings or wood turnings. We have a few around here so I'm sure you've got the same situation there. We have a local guy here named Stephen Hanson who I consulted once about putting together a stair railing in a historical district here in Portland, and I got to visit his shop. Very impressive to say the least.
But what I did notice [in his case] was that there ample sources of balusters & table legs every where from various jobs in the past. Kind of the leftovers which I'm sure served as good samples to view.
But the point is, find someone who does wood turning and I'm confident they'll have a few table legs kicking around to sell for cheap.
Good luck.
Jeeps 04-24-2012 04:51 PM
I am 6'2 - 220 lbs and I can sit on a 18" sq. top table with four 2"x2" popular legs and will never worry about it breaking down. Vertical strength in wood is awesome, its the horizonal plane that makes it weaker. Make a 3" band around the legs under the top, to help on the side to side movement. ..
Lowes has a good assortment of popular pieces in their finished woob rack with the oaks, camber pine etc. good luck
woody4249 05-04-2012 02:32 PM
My thoughts exactly
